Need help with stuck T/B Spacer.
Black 93 Fox
1,995
Vancouver,Washington
OK i got the T/B off took off the 4 bolts and everything else and got the t/b off. Now im trying to get the spacer for it that sites inbetween the plenum and t/b. It is stuck on the back bottom thread.The other 3 are loose but that back bottom one will not budge. You guys got any idea's on how to get it off thanks in advance.
Black 93 Fox
They're studs that its on so if the throttle body is off the egr will come off. The same thing always happens to mine, what I do it keep tapping around it with a rubber mallet and working off, its the gasket thats holding it on, for some reason that one sticks, the TB one doesn't. Just have patience, and keep tapping it with the mallet and it will eventually loosen up.
