need help with t-5
  • Thread starter Thread starter 93killerbee
  • Start date Start date Aug 10, 2004
9
93killerbee
44
ohio
Aug 10, 2004
  • Aug 10, 2004
I need help finding out whats wrong with my trasmission. Its grinding going into forth gear and their is a spinning noise in the trans while in netural with foot off the clutch, as soon as you push on the clutch pedal the spinning noise goes away. Please help thanks.
T
tjm73
2,418
Rush, NY
Aug 10, 2004
  • Aug 10, 2004
Although it's pretty hard to dianose these kinds of noises online, experience tells me you need to look at the syncro's for 4th and maybe the input bearing retainer (right term?) for the spinning noise your mentioned.
stockhatch
536
polar sloth country
Aug 10, 2004
  • Aug 10, 2004
Sounds like a hosed output shaft. The front part of the shaft that mates with the input shaft may be worn and chewed up. This lets the output shaft flop around and when the slider tries to bridge the gap its a no go and grinding results. Had this happen to me once. Went to a friends house to snag an output (he had around 5 T5 donors laying around) and ALL but 1 of his had the same problem.
AC
D
dromeda
146
  • Aug 10, 2004
Try double clutching it going into fourth, if that improves the grinding a little, sounds like your syncros need some help.
stockhatch
536
polar sloth country
Aug 10, 2004
  • Aug 10, 2004
A really easy way to tell if it is the shaft is to drain some of the fluid from the trans. If there is any major shaft damage, you will see little metal flakes in the fluid. If the fluid looks nice and clean(red) it may just be the syncro or a fork pad after all.
AC
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
