Need help with the ignition!!!
pull the #1 plug, stick you finger in it, rotate motor till you feel compression, then a little farther(til poston reaches TDC), pointer should lined up with the 0 on balancer. Then pull the dis. cap off, rotor should point at 1.
if balancer doesnt line up, balancer is bad (rubber cam loose)
if rotor isnt pointing at #1, your 180deg. off. pull dis. then instal with rotor just a hair in front of the #1.
let me know what happens.
Man it's always the little things lol. Yep I looked down there again- I didn't even see the other end of it before. I thought it was odd that it had a circle but I had never set the timing on it before. It was dead on 10* right where it was supposed to be. Guess at least I was pretty good setting it by ear lol. Thanks guys:D. Time to go break something else!
