Need help with understanding numbers
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
So i have my motor on a stand as i work on the actually body and preping it for paint so i decided to work on the motor while it is out as well ... so i take the valve covers off and remove gaskets and i find numbers under each of my roller rockers on top of the heads right where the gasket for valve cover touches the heads ... the numbers range from 1.850 to 1.930 and each number between intake and exhaust valves are all different ... are these numbers for the shims for the valve springs or milling of the valves? can someone help me understand these numbers?
Sounds like installed height of the springs, I do a similar thing when I set heads up.... HOWEVER, they should be very close to the same...or atleast the intake and exhaust common.
Along with the shims and locators (if they have locators) under the springs, same height locks and retainers. If you change anything they need to be checked and reset.
