OK I have been dealing with this for 3 weeks, then i buy a new silicone intake elbow and still same thing is happening.
Here's the story,
Right after the Vortech head unit is the exit whole where you put your intake elbow on. We'll the one that came with the Anderson powerpipe kept slipping off my stupid head unit. So i bought a new 3 1/2 to 4in silicone reducer. It holds much better than the one that came with the Anderson powerpipe, but it is still slipping off! I even tried hair spray from what i read works.
Does anyone else have this problem? How do you fix it! I'm getting really irritated because its consistently creating a stupid vacuum leak because of it slipping off. I also am throwing code p1152, but it only shows up once the stupid intake elbow slips off.
I have run out of options on whats causing this. I even switched from a worm gear clamp to a T bolt clamp, but when i use the T-bolt clamp and i try to tighten it down it starts to slip off the vortech head unit. I which vortech made the lip longer, eerrrhhhhggghh, or beaded the lip.
Should i not be using a t-bolt clamp? Could it be tightening to tight where it forces pressure on it and causes it to slip off? Thats the only thing i can think of right now. If anyone has an answer please let me know, i have searched everywhere!
Here's the story,
