Need help with Wheels!!!!
Hey guys I've got a 90 gt that has eibach sportline springs on it and I am about to swap to a 5-lug conversion. I was wondering if 18x10 saleens in the back and 18x9 in the front with a 5.45 backspacing will fit under my car??? If not what 5-lug parts do I need to get to make them fit or if I should by the 91-93 fenders becuase they are wider. Any help would be appreciated guys. Here is a pic of my car to help you all out. thanks again.
What 5 lug is planned? A 94-95 set up with fox axles would be the narrowest set up and whether or not they will fit I am unsure. I will be running 18x10 DD Bullitts on my fox, and they will be tight but will also fit!
With a 9" rim in the front, i think you would almost have to get the 91-93 fenders, and even then youll probably rub when the wheel is at full turn. I was told that you CAN put a 9" rim up there, but rolling the fender is a must.
