I have a 66 coupe shell and will be installing a complete 1989 Crown Vic 5.0 and AOD to it on a budget. I have the cross member, TV cable and drive shaft yoke for it. I am refreshing the engine and installing a Professional Products Crosswind dual plenum intake, Edelbrock 600 carb and changing the cam to a B303 with ford racing springs. I had all this stored for about 2 years so the carb was rebuilt. Now here is the thing! The engine has a set of E6SE heads (No letters) and the engine has pistons with the small dish in them (No valve reliefs). I will be doing a basic porting on this heads (I know they are not the best heads out there) but it doesn't hurt to tweak them a little at fairly no cost. I also have a set of scorpion 3/8" roller rockers (stud mount) that will like to use on them. The questions are:
1) Is the exhaust smog bump solid or hollow? I heard 2 different stories about it.
2) Any one knows the part number of the 5/16" to 3/8" conversion studs to use 3/8" stud mount roller rockers?
3) Can the thermactor port at the rear be eliminated just by plugging it up?
4) The Professional Products intake requires a Fel-Pro 1250 gasket and I wonder if the intake ports can be opened for that gasket and the exhaust ports to a Fel-Pro 1415? Without any problems?
5) Any suggestions for milling the chamber to a "D" shape instead of the heart shape they have?
Thanks, any help greatly appreciated
