  • SN95 4.6L Mustang Tech
Need more OIL...?
  • Thread starter Thread starter 1/4Horse
  • Start date Start date Aug 25, 2004
1/4Horse
207
12.40 @ 112.98
Aug 25, 2004
  • Aug 25, 2004
Since I had my heads ported and new comp cam 270 grinds installed, I've taken it easy on the car, just not really revving it too high to let everything settle. Anyway I now have over 1800 mi on the new setup and when I rev it past 6300(give or take 100rpm) I get a ticking in the driver's side valve-train. Sounds like lifter noise on my old 5.0,but not as loud.It eventually goes away or if I shut the car off for a couple of minutes(and re-start it) it's gone.The reason I rev it so high is 'cause I had it dynoed and it made power right to 6200 without a chip, just the stock cpu, and it made 302hp and 300tq on a 9:0-1 blower motor, N/A. I figure with the blower I should be able to rev it to 67-6800 and still be making power. Could I be starving the valvetrain of oil at such a high rpm? It has a Stock oil pump.
These are '99 windsor heads and Bullit intake combo, both ported, comp springs and modmax valves.
T
tangerine
555
millen, ga
Aug 25, 2004
  • Aug 25, 2004
I don't understand your post do you have a blower or not. List the mods that you have and I can help you. including injectors and things like that also. the reason why I don't understand is because you put "blower motor N/A".
1/4Horse
207
12.40 @ 112.98
Aug 25, 2004
  • Aug 25, 2004
O.K. It's a '99 Windsor block, bored .030, '99 heads ported with comp cam 270 grinds,new guides, comp springs and modmax valves. I had the bottom end built with forged pistons and Eagle rods over a year ago and have run it with no problems running 12# and shifting at 5800rpm. The heads had additional bowl work done to lower compression a little more, because last year I was running 12# and this year had planned to up it to 18-21#'s with a D1. I drove the car without the blower to break it in, it is a low compression motor and I had it dynoed on a portable dyno just to see what numbers it would make in Naturally Aspirated form.It made power all the way to 6250 when the rev limiter cut in, so I thought with this cam and intake that I should be making power well in the 6K range.
Other engine mods are 42# injectors, 255 Walbro intank, Accufab oval t/b.
1/4Horse
207
12.40 @ 112.98
Aug 26, 2004
  • Aug 26, 2004
Any ideas? Anyone?
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
J
Need Help: 95 Mustang GT Engine Rebuild
  • jurban421
  • Jul 25, 2021
  • Other Auto Tech
2K
Other Auto Tech Jul 25, 2021
jurban421
J
Progress Thread 91 GT - 5 lug swap, suspension upgrade, restoration...
  • Andrews24
  • Mar 31, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2021
Andrews24
