need part info
I have seen a list of tranny's for an auto to five speed swap and can't seem to find it now
so can anyone tell me what five speed tranny's will swap in an 88 2.3
such as ranger t-bird etc. what year models and what not
i.e. can I swap a 93 ranger tranny into the 88 vert etc.
thanks
mike
The 5 speeds that will fit your car exactly will come from any 87-93 2.3L Mustang (T5 transmission). The T5 out of a 5.0L car has a larger input shaft and will not fit unless modified. The T5 out of an 84-86 SVO or 83-84 Turbo GT or Capri RS Turbo will work, but good luck ever stumbling across one of those. They are also the "non-world class" type T5's and are somewhat weaker. I am unsure if a T5 out of a turboTbird would work, but I don't see why it wouldn't. The 87-88 ones did have a hydraulic clutch setup though and the trans-crossmember mount may differ as well, but that I am unsure of. You should be able to find an 87-93 2.3L Mustang T5 fairly easily.
The T5 out of ANY turbo car will have a different speedo gear than yours does, so you would have to change it out.
'87-88 Turbo Coupe T5's are identical to any others except for the speedo gear issue, and they have an electronic speedo drive as opposed to the cable drive on Mustangs, so you'd have to find one of those as well.
okay so I found a tranny
but do I have to have a tranny crossmember from a manual or will the automatic cross member work
I know I need to change the flywheel and get a new clutch pressure plate and throw out bearing and a few other goodies
anyone got any tips to switching out these tranny's
mike
