  • SVT Tech Forum
need pointers on bfore drag
  • Thread starter Thread starter gogoCOBRA
  • Start date Start date Jun 10, 2005
G
gogoCOBRA
18
Virginia
Jun 10, 2005
  • Jun 10, 2005
I need some pointers.. gonna take the cobra out this weekend to dragstrip.. never driven the car hard.. wanna know how to:
1) do a burnout
2) how to powershift (should I or should I not?)
3) what rpm to launch at (street tires and slick)
got 494 rwhp no suspn mod and it's covert. thanks guys!
missouri_guy197
1,441
St. Louis, MO
Jun 11, 2005
  • Jun 11, 2005
1) Unless you have drag radials or other sticky tires I wouldn't do a burnout...street tires won't get much stickier with a burnout and they can actually cup and not give you as much traction...but if you want, you can either press the brake pedal with your heel and press the gas with your toe and let the clutch out and keep good pressure on the brake while you accellerate and the rear wheels will spin...or, you can rev up to about 5k and drop the cluch and quickly press on the brake with your left foot to keep the car from rolling forwards...I do the 2nd way and it works well for me...
2) I wouldn't powershift if you don't want a broken tranny...or if you don't care and want an extra tenth or so, just don't let off the accelerator when you shift...press in the clutch and keep the accelerator on the floor and shift as fast as you can before letting the clutch back out...
3) on street tires and your power level, I wouldn't launch at much above 2k or you'll go up in smoke...with slicks you could probably do a 4k launch and hope nothing in the rearend breaks...
01SN8K
135
  • Jun 11, 2005
well you have planty of power. power shifting is not a great idea like was said. you dont need to unless you wanna walk home. with that much power street tires would be useless. if you run radials then i wouldnt even bother trying to launch as the tires will only spin. slip the clutch out fast and ease into the gas would probably work better. not the best for 60 ft times but help with 1/4 times if you dont light the tires up. if you run slicks with a stock rear then i would say 3500 rpms.
04_snake
116
Upstate NY
Jun 11, 2005
  • Jun 11, 2005
until you get some passes, with slicks or streets, i would just dump at 2500 and let it bog, hook and go. focus on the third yellow light, nothing else once you have staged and when it turns yellow, go. It is too easy to make it complicated and just spin your wheels real bad. try some easy launches and learn the procedure of racing, before expecting to rip a 10.
- 04_snake
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 6, 2026
85GT4V
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • SVT Tech Forum
