need some advice
  • Thread starter Thread starter d.s.s 306x
  • Start date Start date Aug 23, 2006
D
d.s.s 306x
27
Elma wa
Aug 23, 2006
  • Aug 23, 2006
I'm new to this site and would like some help on what to do next
First the car is an 88 gt 5spd with a dss 306x pro bullit trick flow track heat
heads/upper and lower intake and the trick flow 1.7 rockers. the cam is of unknown origin but was told the lift was close to 600. sounds alot bigger than my x303.granatelli 75 maf/bbk 70mm tb /19#injecters/stock a9l comp.
the car seams to pull hard up to the factory rev limiter(how do i kill that?) but driving around it lopes real hard and kinda bucks like its cammed to big? anywho did some 1/8th mile runs and it seams ok 8.42/ 81.74 but was leaving real soft as to not spin to much. i would love some advice to make it faster its not a daily driver so no worries. any help would be great
rd
3,316
63
109
Ocean Springs MS
Aug 24, 2006
  • Aug 24, 2006
Unless its a loaded GT, (heavy) it should do a bit better in the eighth with that much cam and engine. What were your sixty foots?
You did not say what gear it has, but with a high rpm cam, and it sounds like you have one, you need 4.10 gears or better, some sticky tires and some hard launches. A stick car is fairly easy to just drive harder. like a rental car.
You could go to 1.6 rockers and tame it some to pickup the launch a bit.
I'd get the suspension and tires to hook all the power you have now before you try to get more.
50FoxBodyGT
74
Memphis
Aug 24, 2006
  • Aug 24, 2006
Nitrous Cures All
Along with changing gears, I'd recommend a dry nitrous system. They are relatively cheap for the gain you will get. It will help force more fuel to the combustion chamber especially with the larger injectors. Big cams and heads need the extra fuel at low RPMs to launch real well.
D
d.s.s 306x
27
Elma wa
Aug 24, 2006
  • Aug 24, 2006
hey thanks for the input
the car has 3.55 gears but was thinkin 3.73 or 4.10
just got a set of m/t e.t dr 275/35/17 so maybe now it wii hook. it just comes to the factory rev to quick now anyway around that?
gunna try to get to the track this weekend to see what it will do
do i need bigger injectors? seems mine are small at 19 but im new to the fuel injection thing
D
d.s.s 306x
27
Elma wa
Aug 24, 2006
  • Aug 24, 2006
D
d.s.s 306x
27
Elma wa
Aug 24, 2006
  • Aug 24, 2006
hey thanks for the advice
the car has 3.55 gears and was thinkin 3.73 or 4.10 but dont know ?
just got some m/t et dr 275/40/17 so it should hook now goint to try to get to the track this weekend
was hoping that someone could point me in the right dirction on getting past the factory rev limiter
gcwh02
515
pottstown, PA
Aug 24, 2006
  • Aug 24, 2006
as for the fuel system, go 24 lb injectors. Get a 255lph fuel pump if you havent already. As for the rev limiter, you should get a msd 6al with a built in rev limiter. Its probably a good idea to hook one of those up anyway with a nice h/c/i. If you are keeping your car N/A it wouldnt hurt to get 4:10 gears. I personally would get 3:73's since they are a great all around gear. I hope that helps you out.
D
d.s.s 306x
27
Elma wa
Aug 24, 2006
  • Aug 24, 2006
the car has a crane hi 6 with a rev limiter but no matter where its set the car starts missing at 6400. was told its the factory comp shutting down?
D
d.s.s 306x
27
Elma wa
Aug 24, 2006
  • Aug 24, 2006
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Need some advice on upgrading GT-40-X303 heads
  • 93gtmustang
  • Sep 1, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2024
C
Fuel pressure help
  • clayton seiders
  • Aug 31, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 1, 2024
clayton seiders
C
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
