I think I've got the whole process down pretty well as far as spraying the paint goes. I'm just not sure on the mixing process. What I've been doing is mixing the paint 1:1 with thinner/reducer, and 4:1 for the clear and hardener. Everything seems to turn out just fine, but I've been noticing some problems with the durability of the paint.
On to my questions! I painted my brothers car about 2 years ago now, and I was repainting his front bumper a couple weeks ago due to a run in with a ditch or two. I noticed that the area behind the front tires looks like it's been sandblasted down to the original color. Is this just from using cheap paint? Poor prep work? Are there more additives or a different process I should be using? I used a gray primer, sanded it smooth, then put on a couple coats of color, then a couple coats of clear, followed by wet sanding and buffing. I'll be putting a new rear bumper on my car (as soon as I find one) and I don't want the same thing to happen to it.
