need timing help quick
  • Thread starter Thread starter slow93
  • Start date Start date Oct 1, 2005
slow93
406
  • Oct 1, 2005
after i swapped intakes yesterday and had to take the dizzy out something screwed up and now my timing is off.what is the best way to get it back in time,i mean not perfect bc i dont have a timing light,but good enough for it to start and get it to a friends house that does have a light.i need to get it going quick because race time is approaching fast.thanks
sunil6784
620
Boston, MA
Oct 1, 2005
  • Oct 1, 2005
ask your friend to bring you the light?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 1, 2005
  • Oct 1, 2005
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block. Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 1, 2005
  • Oct 1, 2005
Do exactly what jrichker says above with a slight alteration -- instead of lining everything up with the pointer pointing at TDC, do it with the pointer pointing at the timing you actually want to end up with - 10-12-14 degrees BTDC. That will get the timing even closer and make first time starting easier until you can get a light on it.
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
