  • 1994 - 1995 Specific Tech
Need to drop motor 3/4 - 1"
  • Thread starter Thread starter KBCobra95
  • Start date Start date Dec 3, 2006
First Prev 2 of 2
ProKiller
3,064
15
78
PA
Dec 4, 2006
#21
  • Dec 4, 2006
  • #21
have you looked into an aftermarket k-member. that would go a long way in many ways but cost more.
KBCobra95
356
North Carolina
Dec 4, 2006
#22
  • Dec 4, 2006
  • #22
I new K-member is a little much right now. But definetly in the future.
vp6799
124
Massachusetts
Dec 4, 2006
#23
  • Dec 4, 2006
  • #23
I just had to buy new mounts for my 94. I checked autozone, napa, drivers seat, and a local store, they all told me that they use the same mounts for verts and coupes in the 94-95 years. I made them look up part #'s for both models and they were the same. The fox body uses diff mounts between models.
NeverFastEngh
37
Stephens City, VA
Dec 4, 2006
#24
  • Dec 4, 2006
  • #24
I have a convertible with a 351 and a coupe with a 302, the mounts are identical. The conv mounts dont drop or add any strength. I would definately measure how much room you have between your pan and rack. I had to raise the 351 5/8" to keep it from hitting the rack.
droptopford 5 0
427
Dec 4, 2006
#25
  • Dec 4, 2006
  • #25
could a 1" motor drop cause a pinion angle problem where the d/s meets the rear? if the car is otherwise dropped, the fact that the motor would drop and the trans mount would stay at the same position so it would torque on the d/s, right? i dont know if its enough to throw things off, just a consideration
F
forq2
#26
  • Dec 4, 2006
  • #26
Not to hijack the thread...I am wanting to do this swap and I have the Cobra R SVO hood. Its raised a bit. Would this clear efi 351?
KBCobra95
356
North Carolina
Dec 4, 2006
#27
  • Dec 4, 2006
  • #27
Saleen used modified 83 vert mounts to lower the engine. I called Saleen and they no longer carry these mounts. Unfortunately
NeverFastEngh
37
Stephens City, VA
Dec 5, 2006
#28
  • Dec 5, 2006
  • #28
I have the TF R-series intake and I have the cobra R with SVO scoop and it clears the intake by 3/4 in.
First Prev 2 of 2
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 6, 2026
gray owl
G
F
2003 Mach 1 - F1.28 Fuse blows on KOEO
  • fr500mach
  • Jul 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 19, 2025
fr500mach
F
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
