New 347 Look at her isnt she beautiful
what i have done to my 89 vert is full MM road and track box, sn95 5 lug conversion w/ cobra 10th anniver calipers w/ powerslot 13" slotted rotors, sportin 2003 cobras w/ 275/40/17 555Rs out back and 555 extremes up front, 3.55s in back w/ eaton posi, 31 spline mosers and c clip elims, FR alum ds and safety loop, TKO 600 w/ mcleod scattershield and mcleod clutch, as for motor, original 2 bolt main, w/ scat 4340 crank, eagle h beams, JE flat tops at 9:1, RHS heads, comp extreme energy cam .565 lift, got edelbrock performer rpmII w/ 75mm accufab TB, and pro-m 80mm MAF, northern alum radiator, black magic extreme ele fan, crane cam HI-6R ignition w/ rev limiter and boost retard, 42lb injs, 255lph pump, hooker super comp 1 5/8" shorties w/ 3" collector w/ full 3" flows out back, MM 6pt roll bar w/ swing outs, its not completely done yet motor goes in tomorrow
boost is coming soon that whay i went with 42 lbs, have a friend that is running 347 n/a with 42s no problem just have to make sure MAF is calibrated correctly and then custom burn a chip, prolly going with novi 2000 cooled @ 10psi or so, we'll see after i get it in and running,
wet nap, sounds good, haha, watched some videos on streetfire and some other sites, if this sounds half as good as some of those cars wont take much for that nap, haha
