new 347 problems, just finished it, STRESSED OUT! advice needed
I bought a 91 Foxbody after seeing the light. I junked the motor in it after 2 weeks. I got a block from Ford, 347 kit from CHP, trick flow heads cam and intake, 70mm Accufab throttle body, 75mm Pro-m, And 30lb injectors, and the othe misc junk. It started up perfect.
First prob, timing and fuel pressure??? I have it at 12-13 now and fuel pressure at 35psi.
Second is the major one to me. Im over heating. I boild over twice now. I pulled off mu heads thinking that I didnt have the coolant ports open in the back of the block, but they were fine, blocked in the front and open in the rear. I have a 160 thremostat and am running at 200 degrees. I have a stock radiator in it but read of 347s w/ stock radiators. I was by a friend to run a 195 or 180 thermastat and 2 bottles of water wetter. I have about 10 miles on the car and it took me 9 months to build. I'd love to drive it before it snows out.
Third, oil pressure. I have a dummy stock gauge still but it seems to be between 3/4 and all the way high. I have a stock oil pump not a high volume. I was tol taht it will dropp as it breaks in. As far as oil ????
Any advice would be greatly appreciated. This is a fantastic site, thanks
What do you mean by this, blocked at the head gasket or at the intake gaskets? I didn't think any cooling ports were supposed to be blocked? I'm a bit confused.
So let me get this straight, you are running a combo that sounds every bit of 300 hp with the stock radiator? Do yourself a favor and get a very good 2-row aluminum radiator in the first place weather that turns out ot be the culprit or not. Every time you run too hot, you risk doing a lot of damage with those nice new aluminum cylinder heads - they don't agree with high temps.
Also I second the 180 t-stat, 160 is too cold for any engine to run very well and efficient at that.
Just think of this, if you are boiling over, then you are every bit in excess of 240 degrees most likely.
What kind of fan are you using?? If its a stock set up check the fan clutch. If it's electric, what size is and do you know how many CFM's it pulls? Also you sure you got all the air pockets out of the cooling system??
yeah i agree with mike on the stock fan clutch. although you didn't say anything about the water pump so that could also be it.
however, the easiest thing it could be was like timmy said, maybe you didn't burp the system and it is only low on coolant. are you checking it hot or cold?
Yeah, put a good radiator in it. Afco sells a nice aluminum for 179.00. If you said it's boiling over at 200, it sounds like you need a new cap also. Go 16 lb. Also fresh engines will tend to run a little hot for the first few hundred miles till they loosen up a bit. 200 degrees wouldn't bother me on a fresh engine but not much more than that.
Do yourself a HUGE favor, put a mechanical gauge in it, for oil pressure and temperature. Dont go by the stock gauges. Good luck.
mike.
Back to basics.
Before you spend a ton of money, lets do a couple of things.
Lets make sure that you can see the water flowing in the rad. You can pull the T-stat and verify that it is opening in a pot of water on the stove. Use a thermometer to check the temp. Is the T-stat in the right way?
If you are using stock belts, did you get a reverse rotation WP?
Take a step back from it and give it some good thought. You can figure it out without throwing cash at it.
when you said 1/2 blocked do you mean blocked in the front and open in the rear. The reason is, is that I was told by a few guys that the coolant passage is open in front on the pasanger side and open in therear on the drivers side. I didnt do that, I have the head gaskets on the motor where the coolant holes are open in the back. I called trick flow on that, but these guys I know said that was wrong and to call Ford. What up with this info?
Thanks
