  • 1994 - 1995 Specific Tech
New Car!
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Sep 12, 2004
First Prev 2 of 2
cb18201
1,140
CT
Sep 13, 2004
#21
  • Sep 13, 2004
  • #21
why weld in flowmasters? i had that on my car when i bought it, it went from my headers to 2.5 inch bbk h pipe i put on to 2.25 inch stock flow pipes and tail pipes that came on the car. so it was kinda restricting. just get a bbk 2.5 inch off road H and a flowmaster 2.5 inch american thunder cat back and you will be set.
squall9393
534
Oceanside, CA
Sep 14, 2004
#22
  • Sep 14, 2004
  • #22
matthiasj said:
I dont wanna hurt my cooling with underdrive pulleys, so i'm not sure about those, also, i'm pretty sure that the car is stock, and hasent had the timing messed with, but it might have been. But i dont have the timing stuff to check it, and change it. But any input on underdrive pulleys would be helpful.
On a stock cooling system you might see some difference in cooling with the underdrive pulleys, however with a 180* thermostat, aluminum radiator, an aftermarket fan, and a well maintained fill of coolant and you can easily underdrive the waterpump and not have any problems. Another thing to consider though is what you got hooked up to your battery. You might wanna reconsider underdrives because of the alternator if you got amps and what not in the car.
DFG 5OH
1,341
Louisville, KY
Sep 14, 2004
#23
  • Sep 14, 2004
  • #23
Eventually i'd like to put a new radiator and fan, but can i use the underdrive set, with a 180* thermostat, and still be ok? or can i use the set without the water pump pulley?
First Prev 2 of 2
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
