  • 1994 - 1995 Specific Tech
New Clutch slight Problem
  • Thread starter Thread starter DMacRacer
  • Start date Start date Jan 1, 2007
D
DMacRacer
28
  • Jan 1, 2007
I just put in a new King Cobra clutch kit and TOB as well as a new steel front bearing retainer. The problem I'm having is that when I push the clutch to the floor and let off it feels as if it sticks or catches on something. I checked the floor area and found that it wasn't hanging up on anything as well as watched the movement of the clutch fork and TOB and still found nothing. Has anyone else had this prob. Should I replace the clutch Quad too. If so any recomendations.
Thanks David
1TallMF
955
Montreal
Jan 1, 2007
  • Jan 1, 2007
My buddy had a KC clutch in his '95 GTS, and his clutch pedal kind of felt like it was slow to return compared to my stock one, but it worked fine. Maybe its just how the KC pressure plates are made Hopefully other KC users will chime in.
SQUEEZE&STROKE
SOUTHERN CA
Jan 1, 2007
  • Jan 1, 2007
It could be the Pressure plate or it could be the steel bearing retainer catching on the bearing. Did you lube it up? Check the fit before you put it in? If the clutch is not slipping it might not be worth it to take it all out again. Just my $.02
D
DMacRacer
28
  • Jan 2, 2007
Bearing retainer was the same length as the old and I lubed it up, the only visual difference was in the TOB the factory was a two piece plastic and metal, the one that came with the Ford Racing kit was all metal, could this be the problem. It doesn't appear to be slipping, it just releases real suddenly. If I don't push the clutch to the floor it seems to release fine. So I'm thinking that an adjustable Clutch Quadrant kit may be the answer.
99FiveOh
2,051
20
99
J-Ville, FL
Jan 2, 2007
  • Jan 2, 2007
Yeah, sounds like an adjustment issue. FWIW, my King Cobra clutch feels like it clicks/catches at times. I have a tremec with a steel retainer and my clutch has claimed about 5 cables over a 3 year period! It's from it being so hard to push I guess. I won't be using a KC in the future, my brother has been running an Advanced Auto Parts cheapie clutch forever and has no problems, and he's still on his original cable! That's what I'll be getting.. my .02
D
DMacRacer
28
  • Jan 2, 2007
The pedal pressure feels almost equal to the stock pressure and I think it is advertised as being 10% less with more holding pressure, But it sounds like we have the same click/catching problem. Are you running an after market Clutch Quadrent and adjustable cable?
99FiveOh
2,051
20
99
J-Ville, FL
Jan 2, 2007
  • Jan 2, 2007
yup, adjustable quadrant/cable/firewall adj. I'll never put another KC in my car though.
D
DMacRacer
28
  • Jan 2, 2007
Hey for what it is worth, I went to the 5.0 tech section and looked in the tech section and under clutch cable adjustment section there was a bit of info on cables tearing up and the probable cause and probable solution.
99FiveOh
2,051
20
99
J-Ville, FL
Jan 2, 2007
  • Jan 2, 2007
well, they do tear up, but I've used about 4 different manufacturers all failing. All aftermarket cables (well, most of them) will fail eventually, but I'm not getting enough time with mine. My brother's car is easy as hell to push, but mine isn't. My clutch just may have been a bad one from the start.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 2, 2007
#10
  • Jan 2, 2007
  • #10
factory ford cables are tested to be the best....mine is 19 years old and still works fine. I am doing a quad and F/W adj in the spring so I will get another ford cable since I'm in there..
99FiveOh
2,051
20
99
J-Ville, FL
Jan 2, 2007
#11
  • Jan 2, 2007
  • #11
Yeah I hear ya on the cables, I read the write up on Maximum Motorsport's site. I know my problem is the pressure plate. I'm experiencing a vibration that I've narrowed down to the clutch system. Sometimes it gets easy to push and the vibe goes away, but then comes back.
But I know the clicking/catching feel and it's most definately not my steel bearing retainer either, like the OP said.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
