lol, look man, no need to get emotional over this, I'm simply stating the fact....No need to take it from me, give both tremec and gforce a call and ask them which spec you should run with their trannies....they'll BOTH tell you to never run a spec with their product, and they're both known for bullitproof setups.....Why is this? the simple facts I've stated.
Argue as you want, I've stated the simple facts which can be backed up with any amount of research...I'll state it again, the weak link in your drivetrain MUST be the clutch.. If it is not, the next weekest thing will go, which is the trans. Again, simple physics. that spec is way stronger than the trans in your car.
there are better clutches out there for hi hp applications, the spec is not one of them.
It's normal to get defensive over a purchase, it's hard earned money and I understand that, I'm in the same boat as you are.
Perhaps you should not be so open to criticize me.....I've "read" more on mustangs than you will likely ever read in your entire life.
However, what seperates the two of us, is that I don't just read, I do. I do ALL my own work, whether it's rebuilding a t5, or a motor. I've done aod to t5 swaps, several explorer motor swaps, rebuilt t5's, and I've used and tested numerous clutches including YES, 2 spec clutches, a centerforce dual friction clutch, 2 hd frpp clutches, 2 frpp king cobra clutches, a generic brand, stock brand ram, you name it.
My statements are backed from experience, and not from "reading"
Take it for what you will, I'm done here. I simply wanted to state my opinions and the facts for what they are.
I don't like specs, you do. However, when that trans breaks, just don't call me up to fix it..Jeremy
