Went to Torquefreaks today and spent an hour on the dyno adjusting the air to fuel ratio and advancing the timing. End result was improvement from 436/463 to 446/472.
Here is the dyno sheet from the dyno day.
Here is the best run of today. It seems to take a dive at around 4500-5000 rpms. I think it might be the MAF getting close to its limit. This seems to be the point where the maf voltage approaches 4.6-4.7 with a highest reading of 4.9 today at WOT around 6000 rpm. Maybe the tune thinks "hey he's breathing a lot of air, I better add tons of fuel..."
Toward the end of the session, I lost some power due to heat soak but I think the final adjustment will be as good or better than this dyno sheet cause the AF ratio is slightly better.
Thanks to Mike at Torquefreaks.
