new edge coolant leak need advice asap
2vBoogs
arizona
2001 Mustang GT 4.6L V8 – Losing coolant, white exhaust smoke, lots of water from exhaust, and misfire. Need help diagnosing.
I have a 2001 Mustang GT with the 4.6L V8 and I'm having a few problems that I'm trying to figure out.
1. Coolant disappearing
Over the past 3 months I've lost around 1–2 gallons of coolant. I keep having to refill the reservoir but I haven't been able to find exactly where the coolant is going. I'm worried it might be getting into the engine, but I'm hoping it's just an external leak like the intake manifold, water pump, or a hose.
2. White smoke coming from exhaust
My exhaust blows white smoke even after the engine is fully warmed up. The passenger-side exhaust blows a lot more smoke than the driver side. The smoke smells more like gasoline or exhaust fumes rather than something sweet.
3. Lots of liquid coming out of exhaust
I'm also getting a lot of liquid coming out of my exhaust pipes. The liquid looks completely clear like water. I'm not sure if it's normal condensation or if it's related to my coolant disappearing.
4. Ignition coil / misfire code
I have an ignition-related trouble code that I believe is causing a misfire. I already replaced the spark plug but the problem didn't go away. I believe the code is P033, but I need to double-check the exact code. The misfire seems to be on the passenger side, which is also the side producing the most white smoke.
I'm wondering if a bad ignition coil could explain the gasoline smell and smoke, or if coolant entering a cylinder could be causing the misfire.
5. Other fluid leaks
I also have power steering and brake fluid leaks. I've located those leaks, but I'm currently trying to figure out the coolant and exhaust problems. I don't know if any of these issues are related.
What I'm trying to figure out:
  • Could this be a blown head gasket, or is an external coolant leak more likely?
  • Could the misfire be causing the white smoke and excessive exhaust liquid?
  • Why is the passenger side smoking so much more than the driver side?
  • Could a leaking intake manifold explain the coolant loss and misfire?
  • What should I test first before spending money replacing parts?
Any advice from people familiar with the 4.6L 2V Mustang engine would be appreciated. I'm trying to narrow down the actual problem before replacing anything else.
I am planning on fixing the misfire so maybe that fixes the smoke since maybe its unburnt gas based on the smell and i plan on dropping the oil to replace it and see if water is getting in it or coolant or anything and the car has been running fine other then the misfire and smoke please help im also just a teen im not a professional or anything or fully knowledgeable.
Also car only got super hot on me once but didnt cause it to overheat and turn off and theres multiple puddles on the ground some from brake fluid and power steering which is why i cant tell like where its coming from if one of those puddles is coolant.
Grab a pressure test setup. You can pump it up and check for leaks. Get the car on ramps to inspect underneath. There is a very common leak point at the adapter where the oil filter screws jn. That adapter uses a gasket to seal to the block and jt leaks and can dribble down and not make it to the ground.
On the bank you suspect you might have a leak, you can try pulling plugs to see if one looks cleaner than the orher. You can also get a combustion gas trst strip you dip in the coolant to see if any combustion gases present.
My GT dunps a ton of condensation out the exhaust, especially this time of year. Idling will make some decent size pools of water under the tips and exhaust weep holes.
Reactions: squeak93
