New engine in and running
  • Thread starter Thread starter billheis
  • Start date Start date Jan 26, 2004
billheis
117
Longwood, FL
Jan 26, 2004
  • Jan 26, 2004
I finally got my engine in and running!! The bottom end is just fresh, the heads are E7s that I ported and Thumper did the valve job (He does fantastic work) I'm running B cam w/1.7 cobra rockers. Heres were I ran into problems. Ive got the Crane spring, retainer and keeper kit and the retainer height is much higher than stock and the cobra rockers have rails that stradle the valve stem like the old rail rockers (these dont actually center the rocker) The prob I had was the the rails were contacting the retainers. So I ground off 1/8 in and no more contact. Intake is TFS street and TB is 65m FR. runs and sounds great. Unfortunatly it rained tonight and even at part throttle I was all over the road.
G
goldbomb79
374
Indiana
Jan 27, 2004
  • Jan 27, 2004
yea, i just got my new engine in not to long ago, and the weather is so crappy I can't test it out much either. don't ya love rain and snow. lol
mike keirstead
1,121
ROLLING A JOINT
Jan 27, 2004
  • Jan 27, 2004
Bill, congrats on getting in and running. Was that CRANE kit the 44308-1 with the 1.94 installed height?
Damn rain!
billheis
117
Longwood, FL
Jan 27, 2004
  • Jan 27, 2004
Hey Mike, yes it is. The rain has let up today and Im going to have to do some tuning. It feels lean so I'm hoping I can just add some pressure. Ive still got the 19# injectors, but even lean its got some umph!
IndyBlk5.0
1,122
New Whiteland, IN
Jan 27, 2004
  • Jan 27, 2004
bill, did you get your rings replaced and all your bearings? is the engine running any hotter than ussual? im wondering what normal things happen when you get exactly what you did done, becuase i am having the exact same thing done all the way down to the crane rockers... thanks!
billheis
117
Longwood, FL
Jan 28, 2004
  • Jan 28, 2004
engine
Hey Indy, I replaced the main & rod bearings w/michigan bearings and just polished the crank. Sealed Power rings just honed bores. New Oilpump, FR oli pump drive shaft. B cam, FR roller lifters, FR pushrods, Cobra 1.7 bolt downs, FR timing chain set, Thumper 5 angle valve job, all felpro gaskets, TFS street Intake, FR 65mm TB, Kirban afpr, Mac shortys, Mac cai, Granatelli (Pro M)MAF, 180 stat 3 row radiator. Runs right on 185. Ive got the fuel pressure at 42 and still has a bit of lean surge at cruise but Ive still got stock 19# injectors. It runs fantastic but can tell theres still something more I'll jsut keep tuning. Hope yours turns out as good as mine.
Bill
mike keirstead
1,121
ROLLING A JOINT
Jan 28, 2004
  • Jan 28, 2004
What exactly did you have to modify on the rocker. I am using the same kit and 1.72s.
billheis
117
Longwood, FL
Jan 28, 2004
  • Jan 28, 2004
rockers
Hey Mike, with the spring kit the installed height to much igher than stock and the part of the valve stem sticking out is reduced, and the Ford racing rockers which are made by Crane (are thier energizer series) and have rails on either side of the roller tip. I just ground a small amout of each rail. Just check when you get everything together that the rocker doesn't contact the retainer. I talked to crane and ws told that this is not normal but have heard of it.
Bill
mike keirstead
1,121
ROLLING A JOINT
Jan 28, 2004
  • Jan 28, 2004
Bill
I think I will be OK. Thanks Bill. How does the motor feel now. Have you tuned it yet. I LOVE A NEW MOTOR.
thumper460
3,022
Orange Park , Fl
Jan 28, 2004
#10
  • Jan 28, 2004
  • #10
rains gone... now its going to 29 degrees... Dont you just love the N. Fl weather??
Just me............................
Thumper
billheis
117
Longwood, FL
Jan 28, 2004
#11
  • Jan 28, 2004
  • #11
engine
Hey Mike & Mike, yeah this weather is crazy. Of course with thecool dense air it feels much stronger. I messed around a little today and have the timing at 12 ( I installed cam 4 advanced ) and fuel pressure at 43psi and feels real strong. The road that leaves my house is a mile long and somebody has very nicely marked off a 1/8 mile. I tried on the way home tonight (no one on the road) and spinning badly in 1st and part of second crossed marker at about 80 or 82. I figure thats not bad.
Bill
mike keirstead
1,121
ROLLING A JOINT
Jan 28, 2004
#12
  • Jan 28, 2004
  • #12
Sounds good. How do your plugs look.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jan 28, 2004
#13
  • Jan 28, 2004
  • #13
Congrats on the engine. I got mine in about 3 weeks ago and just really got it running how I like last weekend. Has less than 250 miles on it.
If that surge was reduced or eliminated with more fuel pressure, then you definitely were running lean. Mine was lean with stock injectors and 52psi, but I also have a more demanding engine. With 24s and 42psi, this thing is a beast after 2500rpm, and I havent even gone past about 3300 yet.
billheis
117
Longwood, FL
Jan 30, 2004
#14
  • Jan 30, 2004
  • #14
engine
I finally think I've come close tothe fuel pressure. I'm 45psi and its running real clean. Plugs jsut have a slight tan color almsot look like they havent been run at all. Looking forward to taking to the track and see what it does
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
