Hey all! Just traded a couple cars for an 88 notchback. The car is pretty much setup for track use. It is a 306 (I think) with a custom turbo added to it. I cant remember the trim on that turbo but its pretty bitchin. Its a very custom application so I'm learning a lot about it right now. (tuning is done on a laptop, the rear has discs, AC and power steering deleted, turbo plumbing is all custom) I do have one issue keeping me from driving that I need some help with.
My issue is that the cars radiator fan stopped working. The PO drove to my house over an hour from where he is from so the fan was working great up until right after I took ownership of course. It appears to be a taurus fan hooked up to a couple relays and switched by the factory temperature sensor. I was trying to see if the fan was borked so I rigged up a 30a switch directly to the solenoid terminal to the high speed wire of the fan. It smoked once out of the switch but the fan worked for a bit so I closed the hood and drove to the store. by the time I got to the store the fan had gone out. I'm pretty sure I should have put the switch between the ground off the fan and not between the power (and should have used a fuse.)
Does anyone know how to make a switchable turn on for this fan using the existing relays? couldnt I just ground the wire going to the temp switch to turn the fan on? (I have no idea how temp switches work.) Im going to get another fan after work but dont want to burn it out if the problem was my ghetto rigged wiring.
As you can tell I'm quite a noob when it comes to electrical. My other car is a grand national that I rebuilt the motor and did some wiring on but all under the supervision of someone smarter than me.
looking forward to learning!
