garystocker Member Jan 2, 2005 305 0 17 New Jersey Sep 5, 2005 #1 Sep 5, 2005 #1 35lbs key on 44 lbs running 40lbs with motor/key off this right?
garystocker Member Jan 2, 2005 305 0 17 New Jersey Sep 5, 2005 #2 Sep 5, 2005 #2 These numbers look ok to you?
Euphoric306 New Member Apr 5, 2004 905 0 0 Sep 5, 2005 #3 Sep 5, 2005 #3 it only really matters when its running... and thats darn good maybe your battery is a little low, so if the alt. isnt running the pump isnt getting max voltage?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Sep 5, 2005 #4 Sep 5, 2005 #4 WOT simulated-pressure would be what matters the most - yours is good. Gary, do you have an AFPR? It kinda looks like it. But like was said above, that pressure is good all the way around. Good luck.
garystocker Member Jan 2, 2005 305 0 17 New Jersey Sep 5, 2005 #5 Sep 5, 2005 #5 Stock FPR...I figured the gauge results would let me know if I needed a AFPR. I am very happy to hear all can stay as is! Thanks as always... gary
