Hey what's up Guy's.Been lurking around for a few weeks and figured id register.Let me start off by telling you what i have planed.I found a pretty clean black 95 v6(for now)to tell the truth i was looking for another fox body(had 2 back in the day 87-89) but a fellow member turned me on to the 94-95 didn't realize how cheep one could be had for
anyways.First I'm pulling out the v6 and 7.5 rear.I know there's going to be some haters but I'm putting a Gm 6.0 with l92 heads(These heads flow 320 cfm right from gm)going to keep it injected most guy's run carbs on these motors,putting in a 8.8 rear don't know if i want 410's 0r 373's not sure if I'm going to spray this motor we'll see should run good with just a larger cam (should put it around 500hp)for trans I'm going to be using a 350 turbo with a 4500 stall.Also going to put a tubular front end kit and a 4in cowl hood.
