- Sep 27, 2009
- 16
- 0
- 1
Hello just signed up with you guys. My name is Donavan I have a 88 Foxbody here are some of the mods. 331 stroker with wiesco pro tru forged pistons, steel H-beam rods, forged steel cool cased stroker crank Main girdle, all ARP bolts and studs, Chet Herbert custom grind camshaft,comp cams magnum roller rockers , tru roller timing chain SFI approved summit front balancer, polished Edelbrock performer heads fully ported and polished with flow sheet, polished Edelbrock performer upper intake ,30# red top injectors . Polished C&L 76 mm aluminum power elbow, Pro-m mass air flow sensor,MSD 6A, cold air intake polished 70 mm throttle body and egr spacer. Polished Edelbrock water pump, BBK underdrive pulleys, BBK adjustable fuel pressure regulator with pressure gauge. BBK 1 ¾ full length headers and X-pipe with cats, cat back with flowmaster 2 chambers. Tremec TKO transmission with Steeda TRI-AXE shifter,Fidanza aluminum flywheel, Spec 26 spline clutch and pressure plate. 31 inch aluminum radiator with electric fans.Ford Motorsport aluminum driveshaft. 3.73 rear gears, maximum motorsport full length subframe connecters, ride height adjustable lower control arms, double adjustable uppers. Line lock installed. Rear disk brakes.
Best time to date 12.93 @ 107mph last weekend at PSCA in Fontana with a 1.85 60'
