New Heads, Don't Know Cam.
Are the heads already on the car? Stock is 1.6, and thats what you will find most common in the aftermarket as well. You really need to know what cam you have so you can install appropriate springs and pressure. You should also check piston to valve clearance with new heads and your decided rocker. Really, 1.6's are a safe bet.
Joe
Reactions: clement
Joe
No, heads aren't. I had to pull the motor because the oil pump broke, and the engine started knocking. I decided it'd be a good time to put them on. I'd really like to just use the same cam, but if its smarter to just buy a new one, I could just buy a new one. I'd just rather not spend more money than I can afford.
