I replaced the hood hinges on my 69 Mach 1 since the old ones were worn out. However, the new ones aren't doing a good job in holding the hood up!! There's not enough room to stick my head under there. Instead of the 45 degree angle that seems to be the norm for Mustang hoods, my hinges can only hold the hood at less than 30 degrees. Also, the hinge springs are loose and can be easily moved when the hood is open. I tried moving the hinge spring on a 66 with original hood hinges and they wouldn't budge.
It seems to me the ultimate solution would be to either replace the hinge springs with something stronger or shorten the hinge springs so that it actually has some tension. Easier said than done though....
Any ideas??
Any ideas??
