Been having this problem since I put the engine back together over the winter.
I can reset my idle, set TPS voltage, unplug the battery for an hour, clock my Mass Air Meter, check for vacuum leaks for months on end, retighten the 10-pin connectors, and nothing fixes this problem.
I've replaced every sensor in the car except the Mass Air Meter, not thinking it could affect idle this much. But now I'm thinking differently... please help. Here's the problem-
I can set the idle to 900rpms, just fine. But after about 30 seconds (and usually at EVERY stop light) the idle drops to around 500rpm or below, causing the car to die sometimes. Then after driving, or revving sometimes it will begin to idle correctly. I can reset my idle to 2000rpm, and will still do the same thing. The faster I set the idle, the faster it drops to 500rpm, and then will climb back up to where I set the idle again. The idle will drop even if the IAB valve is unplugged.
Could it be my Mass Air Meter causing this? I'm out of ideas, and the Mass Air Meter is like the most expensive sensor to replace just to find out it didn't help.
The only codes I get are for my emmsions stuff being gone...
Things new, or that I've tried -
2 New TPS Sensors (one was probed to death), new IAB valve, new ECT sensor, cleaned the ACT sensor, clocking Mass Air Meter, completely cleaned the upper intake/throttle body, cleaned Mass Air sensor, replaced injectors, replaced Fuel Pressure Regulator (stock), cleaned/tightened 10-pin connectors, replaced A3M computer with A9L
I have A9L, 19# Injectors, STOCK Mass Air Meter, Cobra Upper/Lower, stock heads.
Please help if you have ideas, I searched for a similiar problem, and could not find anyone else thats been through this.
