new intake manifold
  • Thread starter Thread starter rudy herrera
  • Start date Start date Aug 24, 2009
R
rudy herrera
110
Aug 24, 2009
  • Aug 24, 2009
i just bought the bbk ssi 5001 in take manifold with fuel rails and a 70 mm throtle body i purchase this without thinking now im not sure if im going to have to use a cowl hood does any one know if it would clear with the stock hood
stykthyn
5,232
2,652
223
gainesville
Aug 24, 2009
  • Aug 24, 2009
take it back. if you actually get the thing to work the way it is supposed to. you will be in the minority.
R
rudy herrera
110
Aug 24, 2009
  • Aug 24, 2009
why there a pian in tha ass or wat
cenok is family
1,409
69
79
Norman, Ok
Aug 24, 2009
  • Aug 24, 2009
i've heard more horror stories about that intake then anything else. fuel rails don't seal, fitment issues, etc.
stykthyn
5,232
2,652
223
gainesville
Aug 24, 2009
  • Aug 24, 2009
its just one of those things that did not successfully make the transition from paper to reality.
they sure look cool though
67coupe
658
402
93
Huntsville, AL
Aug 24, 2009
  • Aug 24, 2009
OP, google BBK SSI fuel leak.
From working 8 years in manufacturing and reading of all the horror stories here, my money is on a tolerance stack. The dimensions of 4 components determine whether or not there is enough force/contact on the o-rings for a good seal.
1) Lower intake - width between mounting holes for the fuel rails
2) Cross-over tube - length of cross-over tube
3) Depth of hole in each fuel rail
4) Thickness of fuel rails at mounting bracket
Difference between max and min dimensions for these parts might look something like this:
width btw fuel rail mount at max + cross-over tube at min length + holes in fuel rails at max (depth) + width at mounting bracket max = probably 2-4 mm
Easy to see how reports of a cross-over tubes that moves laterally after install, are possible.
rbonella
409
@ home
Aug 24, 2009
  • Aug 24, 2009
Like mentioned above, TAKE IT BACK!!!!! 67coupe brought up a great point, someone posted a thread about a month ago titled "BBK SSI INTAKE WARNING" (i think thats right) it was a hot topic for weeks. They're known to leak fuel with the potential to be VERY DANGEROUS. Just like anything, I'm sure there's plenty of happy customers running that intake with great results. But after reading the warning thread, I would never consider that manifold which is too bad cause it's kind of cool looking and different!
Dino Dino Bambino
1,673
90
79
Cyprus
Aug 25, 2009
  • Aug 25, 2009
x2, and get the Edelbrock Performer instead. I know it doesn't look as sexy as the BBK SSI but it performs at least as well and doesn't have any quality issues. I have one and I love it.
K
Kevins89notch5.0
5,864
Aug 25, 2009
  • Aug 25, 2009
I don't care if it made stock 5.0s dyno at 400 at the wheel, it is the most god awful looking intake EVER!
Celeb
20+ Year Stangneter
Sep 8, 2002
736
Here and there
Aug 25, 2009
#10
  • Aug 25, 2009
  • #10
+1 even in the unlikely event you're somehow able to keep it from leaking fuel, it redefines ugly
R
rudy herrera
110
Aug 26, 2009
#11
  • Aug 26, 2009
  • #11
thanks for the for the help this thing is going back
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
