New K-member = higher ride height?!
Otto1970
28
South Florida
Say it ain't so. a guy at work says that I will have to cut my Steeda sport springs after I install my AJE tubular K in order to preserve existing front end ride height. If this is true, it would have been a useful piece of information when I asked AJE about retaining my Steeda Stage 3 setup w/ their piece at the time of purchase!
It isolates the spring from the frame for a reason though :P If this is just a DD then keep your isolators or the springs will transmit any and all vibrations right through them to the frame.
Put the springs in the correct way with the isolators. Cutting springs is the worst thing you can do to try and correct ride height. Losing weight in the front of the car might allow it to sit a little higher but I'm sure you won't even recognize the difference. I'm running an AJE k-member and I didn't notice any difference in the ride height. If ride height is a big deal then switch to a coil-over set up like I did where you can change the ride height with the turn of a nut.
Yeah, I would never consider cutting or heating springs inorder to adjust ride height. That would be a return to the bad ol' days of suspension re-engineering. I got to think that you guys are right about the subtlety of what's likely to happen when all is said and done. It was just something that I did not consider when purchasing the k-member. I decided against the coil over set up because before I took everything apart, I remember the top inside wheel/tire surface ( 17x9 fake Cobra w/ 5.75 backspacing on 245/45 rubber) being so close to the strut.
