New Mach 1 wheels on An old Mach 1
I just installed a set on my '70 Mach during Christmas week. They look great, but I don't have any pics right now. I'll get my father to take a couple when he gets back from his business trip.
For my install, I used a set of billet aluminum 1" hub-centric spacers all the way around. I have to admit that clearance is tight on the front and I may have to roll the fenders if I lower the car much more. The 1" spacers are perfect for the rear.
Hope this helps... and I'll post pics the moment I can.
I'd mock the wheels on the car and see how much space you need to push the tires toward the body. That'll tell you how thick of spacers you need. I'm guessing an inch, but I'd test fit before I ordered. Be sure to get the bolt on spacers and not the chintzy slide on ones.
Edit add: Also, check out Corral.net and the wheels classifieds section. Tons of guys there sell the new wheels cheap. That site is more popular with the Foz and newer Stang guys.
Here are a couple things...
The backspacing on the OEM Ford Mach 1 heritage wheels is 5.72". For my car 4.85" would've been ideal, but I could only find 1" spacers so that's what I used.
I got the spacers from a guy on eBay. They're billet 6061 aluminum, include grade 8 studs and matching nuts, and are excellent quality (even if they are made in China apparently). They were $142 for a set of 4 shipped to my door. I got the hub-centric versions for extra strength and stability, but I had to hone the center an extra 1/16" to get them to fit the stock front hubs. They fit the rear perfectly.
If you're specifically looking for a set of the Mach 1 heritage wheels, I'll give you the best tip I know (and the one I used to get my wheels): check the classified ads on http://www.mach1registry.org/forums/ . Lots of guys upgrade or swap, so you can usually find good sets for cheap. I lucked into finding a local guy listing a set of very decent (not perfect) wheels with Cobra center caps and they still had the original 245/45/17 Goodyears (with 20K miles left in 'em) still mounted, all for $250. SCORE!
So, all told, including wheels & tires ($250), spacers ($142), aftermarket billet center caps ($80, but they were a birthday gift), and new lugs ($45), I'm into the wheel swap for a grand total of $517. That's damn cheap for wheel swap, especially for 17s, and extra especially for the impact and difference they make in the appearance of the car.
One last thing... just a warning, but the wheels are heavy! I mean real heavy... like 24 lbs. each. But ya gotta figure they're engineered for OEM which means they're gonna be durable. Considering I've seen a couple guys bend their 17" Torq Thrust 2s, I don't mind the extra weight for a street car.
DarkBuddha said:
See... this is what I'm talking about: http://www.mach1registry.org/forums/showthread.php?t=43701 Seems the guy almost can't give 'em away...
Or this one... no replies at all... http://www.mach1registry.org/forums/showthread.php?t=43830
And here's a guy that sold his set for $300 + shipping... damn cheap! http://www.mach1registry.org/forums/showthread.php?t=42972
Right on boys good work, i don't really care about the used wheels cause i live in Canada not really worth it. Not only that I can buy brand new ones from my work (Cariboo Ford Quesnel, BC) for $400 on the door step including tax. But hey thanx anyways just gotta figure that back spacing i guess
I have a '69 Mach 1 and I'm running late model style aftermarket 17x9 knock-off Mach 1 wheels on the rear. They came chrome with black painted insides. I got the set of 4 new, off e-bay for just over $600 delivered to my door. They fit very nicely on the rear with no spacers. I mounted P275 tires on them and rolled the fender lips, and they look awesome. There is just no way to make the 17x9s work with the stock spindles, so I bought 2 Ford Racing 17x8 chrome Mach 1 wheels with BFG P245s from Tire Rack for the front. I'm running the Wilwood aluminum hub, which sticks out about 3/8" farther than stock. I then added 1/2" spacers to make them clear the spindles. The Chrome Ford Wheels don't come with the insides painted, so I did it myself. A little cheesey loooking when up close, but fine if you stand 10 feet back. I put the running pony inserts in all 4 to make them look more like they belong on the car. I'll try to take some pics, but I've been having problems with them coming out too dark. I also tried some Saleen 18x9s, but didn't like the look of the larger wheel. Just my opinion, but I like a little more rubber on the rim.
69gmachine said:
I have a '69 Mach 1 and I'm running late model style aftermarket 17x9 knock-off Mach 1 wheels on the rear..... They fit very nicely on the rear with no spacers. I mounted P275 tires on them and rolled the fender lips, and they look awesome.
I'm surprised you had to roll the outer fender lips in the rear. Was it really that tight or were you just playing it safe to avoid scarring up the sidewall?
I previously had P255 60s on 15x7 Torque Thrusts, and the sidewalls got cut when I hit bumps, so I didn't want to take any chances since these are 275s. The 17x9 wheels actually fit much better than the 15x7s did, so it may not have been necessary.
I've been frustrated by gremlins for a year. I finally got the brakes working well. After trying two used original 68-69 dist blocks w/proportioning valves and both of them leaking, I bought a new '70 style dist block and all new lines and added an adjustable valve in the rear line. I still need to fine tune the bias, but it's working good enough for street duty. The front calipers are used from a C5 'Vette, the front rotors are 12.72x1.25 Wilwoods, on an aluminum Wilwood hub and the Master Cylinder is a 1.125 Strange Eng. The rear brakes are '85 Caddy Seville calipers with integral parking brake, and '85 Lincoln rotors.
When I drove it last the secondaries started sticking... almost ran away from me. I ended up replacing everything but the bolts that hold the baseplate to the main body. The main body is now a Proform 3310 style 750 with no choke tower, the baseplate is billet, also Proform. The metering blocks are billet QuickFuel, as is the adjustable secondary housing. I just got it to idle good today @925 RPM.
Now I noticed an oil leak at the back of the intake:bang: ... Crud! Seems like I'll never be able to put the hood back on!
Hey 69gmachine, that looks great! Looks like a helluva machine you're building too. I have to admit that I'm still a fan of the machined aluminum finish more (more of the OEM look I like I guess), but they really do look good in chrome, especially on a nice red '69. BTW, you ever post over at pro-touring.com??? There are a few '69-'70 folks over there now and I know I'd love to see more.
