Thanks couldn't figure it outWeak or hot starter motor assembly.
Off topic but, rotaries do this when they're low copmression/done. Starts fine cold, hot? not so much.If it's cranking over but not starting when it's hot well, that's a different matter.
Crank cold start no hot start meaning drive around and turn off wait 3 hours then startNeed to clarify here.
Crank, no start?
Or
No crank?
Both have different potential causes.
And I need exhaust workCrank cold start no hot start meaning drive around and turn off wait 3 hours then start
I still think he means that the starter won't roll over when it's hot.Ok. There are a few sensors that will cause that. Have you pulled codes?
Next time it won’t start when hot, depress the gas pedal to the floor. This puts the ECU in “flood clear” mode and will not fire the injectors. It may start now, especially if one of the failed sensors is causing an overly rich condition.
That still does not answer the $1,000.000 question. When it is hot and not starting, 1. does the engine turn over with the key in the start position, 3. does it just click 2. Does it do nothing?Crank cold start no hot start meaning drive around and turn off wait 3 hours then start
