Hi, I am Derrick and I have had my 2003 Mustang GT she was brand new. I finally was able to buy a 2011 Ford Fusion and give the old girl a rest. I have recently started the process of turning her into a trackday/autoX car. Recent mods are as follows:
MM K-member (with 2-point brace)
MM Front Control Arms
MM Torque-arm
MM Panhard Bar
MM XL Series Full-length Subframe Connectors
MM Coil-over Conversion Kits, Front and Rear
Coil-over springs
MM Caster/Camber Plates
MM Aluminum Rear Lower Control Arms
Bilstein HD series struts
Bilstein HD series shocks
MM Adjustable Rear Swaybar
MM Aluminum Steering rack Bushings
MM Solid Steering Shaft
MM Bumpsteer Kit (adjustable outer tie-rod ends)
MM Strut Tower Brace
MM Front Swaybar Relocation Kit
Front Swaybar Bushings
Front Swaybar End Links
SLP X-pipe
SLP Loudmouth Exhaust
Tri-Ax Shirt Throw Shifter
I already have a ton of questions for you guys I will be posting in the forums!
MM Torque-arm
MM Panhard Bar
Coil-over springs
SLP X-pipe
and yes a proper introduction requires
ics: Oh and congrats on that Fusion, by far one of my fav sedans. I almost bought one of those over my mustang, just couldn't see myself happy with it for too long since it was my new DD.
