So I just installed the MM CC plates and had an alignment done however the top nut that holds the strut was finger tight. I drove a few hundred miles down I95 and started to hear a bump like something was hitting my hood and sure enough it was the passengers side strut nut that had come loose and the drivers side I also tightened with my fingers.
How tight should these be?
They are the Tokico Blue series struts. I used the small washer under and then small washer on top followed by two thick for those of you that are familar with the MM CC Plates.
Thanks!
TF
Thanks!
TF
