New Motor Mounts - should I use Poly or Rubber???
I am trying to eliminate some clutch chatter that has shown up since my engine rebuild, new clutch, flywheel resurfacing, etc. and have read that sometimes a torque strap and new motor mounts make a huge difference.
I did not change my mounts when I had the engine out since they looked good and am thinking I should try that before I tear the transmission out.
Can anyone give me their opinion on poly vs. rubber mounts?
I assume I only need to replace the part with the rubber (part number 6038-7 or 7P at NPD) and not the frame mount. Is this correct?
Also, how hard a job is it to change the mounts on a '69? Can I get to the mounts fairly easily with the engine in the car? I have an engine hoist I can use to lift the engine while I do the job...
THANKS!
THANKS!
