It's kind of a long story.... This motor has been trouble from the beginning for way more than just this. I know new motors and modified (especially stroked) motors place more of a demand on your cooling system, but mine is almost undriveable. With the old motor, it never got hotter than 180 degrees, or the "OR" area. Now, it goes past the "M" and occasionally the "A" of "NORMAL" on the stock gauge. The fan does not appear to come on until after the "M" is almost passed. I have tried getting it to boil over, as it does not want to and there appears to be air in the cooling system. The upper radiator hose, when pulled, reveals coolant recessed into the thermostat, like it's not getting around. I installed a 180 degree thermostat to help combat this new motor's propensity to get hot, but it's having little to no effect. It does keep the temp from exceeding the "A" anymore. The water wetter I poured in looks to have little effect as well. I could swear my fan came on sooner with the stock cobra motor. I realize I should modify my cooling system, but it should be at least driveable, right? Anybody with any manner of experience, suggestions or comments would be greatly appreciated!! Anybody know how to decode the stock gauge?
here's the short list: CHP pro street all forged 331, AFR 185s, Comp blower cam, 7 quart kicked out sump pan w/ higher volume pump, stock cobra upper and lower intake with spacer, 65mm TB, new water pump, stock oil cooler, and I don't know what else might make a difference....but that's the short list.
...a motor like yours and you know she's gonna run a tad hotter...
