New Product Beta Testers Needed - Pony Express Performance
HuskerCobra96
741
Overland Park, KS
Moderators, please note: I cleared this with Mike Raburn in advance.
This post is a two-part request.
First, we've just finished development on our enhanced 1999+ COP Tachometer adapter. As most of you know, we already have a 1999+ COP Tach adapter - "Tach Adapt" on the market, and a good number of you already use our product.
With our new unit, we've added a fully functional RPM window switch for Nitrous and/or shift light activation. The new unit can be used on 1999+ Mustangs for the following purposes:
1999+ Ford Coil-on-plug tachometer adapter
Window Switch for Nitrous
RPM Switch to run a shift lamp
Or all of the above at one time.
In fact, you'll also be able to use the unit on conventional coil cars, with 4,6, or 8 cylinders, so if you own a fox body and need a window switch, the product will also work.
Here's the two part request.
1. We need a couple of people to test out the unit for us. If you currently are running Nitrous and need a window switch, and can install the product within a couple of days after we ship, send us an email. If you want to install a shift lamp that needs an integrated window switch to run the shift lamp, send us an email. We know the COP Tach adapter part works, so we don't need people to test this aspect for us.
Email: [email protected]
NO private messages please. Email only...
2. We also some ideas for product names for this new product. Our current COP Tach Adapter is called "TACH ADAPT" so we need somethig more creative for this new product. The winning product name we choose will receive either a set of our MIL Eliminators, one of our Traction Control Disable modules, or a free Tach adapter, your choice.
Currently, the retail version of this product won't be available until early next year, and will be priced cheap compared to other options on the market.
Help us help you. We'll only be able to accomodate a couple of people for testing, but will respond to everyone's emails. Please give us a quick paragraph on your setup and why you'll be a good testing candidate, and the beta unit will be provided free of charge.... All we ask in return is timely feedback so we can move ahead with production.
I look forward to receiving feedback, and look forward to keep bringing cost effective products to the table..
Keep the rubber side down, fellas.
Good question.
It's an integrated module with the following benefits:
1. COP Tachometer Adapter
2. Window Switch - Ability to set lower and higher RPM ranges
3. RPM switch (for a shift lamp)
A window switch only allows for #2. A tach Adapter only allows for #1, and our unit will allow for all three. Plus, it will be under $70 retail when it's released early next year.
