If changing the gear did not make any difference, then you porbably have an issue with your speedometer or the cable.
Cream is an odd color for a tranny gear. It could be yellow or tan, although tan is an AOD speedo gear.
To know exactly which speedometer driven gear you need, we need to know a few things:
Number of teeth on the speedometer drive gear, or the gear's color.
Tire size.
Rear axle ratio.
Take a flashlight and look in the hole that the speedometer driven gear goes into. You should be able to see the drive gear, and note its color. A 7-tooth gear is yellow, and an 8-tooth gear is green. On the off-chance that you have a 6-tooth gear installed, it would be black.
An 18-tooth (yellow) driven gear would be correct for a pre-1990 5-speed, with stock, 225/60R15 tires. A 21-tooth (red) gear would be correct for 1990 and later 5-speeds with those same tires.
