new stang...horsepower goals
Since you just want streetable horses, and you already have the intake, rockers, and e-cam why not just buy the cheapest aluminum heads you can find and slap on the needed valve springs for your e-cam. I would also recommend 24lb injectors or 30s if going the charger route. After this you can either throw on a 100 shot of NOS or a simple used supercharger. Im sure you will surpass your goals and spend less money than the combos mentioned above. good luck!
had nitrous in a coupe i had. not really wanting to go that far with this one. i think ive come to the conclusion that for now im gonna settle with the E cam and scoop up some gt40 heads and play around with it til it gets boost. then i will rethink the cam. thanks for all the help guys. :SNSign:
300rwh is a lot more obtainable. Look into the TFS kit. Only thing I would add would be a new set of lifters and you should be set. Other supporting mods like 24 lbs injectors/maf and fuel pump would be great but not absolutely necessary with the kit.
Kevin
