New thoughts about the drive shaft vibration issue...please read
  • Thread starter Thread starter 85_SS_302_Coupe
  • Start date Start date Aug 28, 2008
1 of 2 Next Last
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 28, 2008
  • Aug 28, 2008
I was flipping through a Car Craft mag and ran across a reader mail piece that talked about a drive train vibration. It sounded an awful lot like the problems so many Mustangers have that's usually "solved" by getting an aluminum shaft. Well the guy answering the mail said the problem is that the guy's car is lowered (he mentioned that in the article) and that changed the transmission/driveshaft angle and that's what is causing the vibration. He said that most shafts are designed to only have around 3 degrees of angle at the universals and lowering a car causes this to be too much angle and the universals are what cause the vibration.
SO, has anyone ever considered this? I figure it's logical since most people have their Mustangs lowered. I know most people blame it on gears, which could also be an issue, but the shaft angle really makes sense to me. The guy said a quick fix is to raise the tail of the transmission up with some shims and see if that solves the problem. Is there anyone with the vibration problem that would care to give this a shot and tell us if it changes anything?
93 LX
3,081
Norwalk, CA.
Aug 28, 2008
  • Aug 28, 2008
My Capri had this high speed vibration. I fixed it by swaping out my Mustangs DS in place of the Capri's. At the time I have the DS's out of both cars. Neither car has any high speed vibration. Go figure! LOL
BTW my Mustang is lowered 1" in the front and 1.5 in the back. The Capri is lowered .75 in the front and 1" in the back. The Mustang sit level and the Capri sits at a slight rake.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 28, 2008
  • Aug 28, 2008
Well my buddy also told me that the "dogbone" on the rear end is actually matched up to the gear ratio...and that swapping the gear throws that balance off and that's what causes the vibration. I've never heard any facts that confirm that but i also know there's not a lot known about the dogbones either and most people just pitch'em.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Aug 28, 2008
  • Aug 28, 2008
The dogbone cancels out drifeshaft harmonics. TCCoA Transmission Article - Page 17
My driveshaft had a bad vibration a couple years ago, so I put new U joints in it and I haven't had a problem since.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Aug 28, 2008
  • Aug 28, 2008
ive had 2 foxes that were lowered and they almost sat on the ground, and I never had any probs with vibes although I put new u joints in both of em, just for the heck of it...
just4bob50
504
Pa.
Aug 28, 2008
  • Aug 28, 2008
can some one put up a pic of what you are reffering to as the ( dog bone ).
I had a bad vibration on the LX i bought a few months ago, turns out the DS had 7... yes 7 counter weights on it.
Now with my new motor in I get a slight vibration at 55mph or so weather Im in 4th or 5th. The rear tires have threads showing and Im assuming its rom the tires, but I would like to know about what you were reffering to.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 28, 2008
  • Aug 28, 2008
The "dogbone" is a cast iron weight bolted to the bottom of the differential housing and is shaped like an oversize dogbone. Its sole purpose is to dampen out any vibrations in the driveline.
Cougar5.O
87
Manchester NH
Aug 28, 2008
  • Aug 28, 2008
Lowering the car reduces the driveshaft angles - doh! So much for what you "heard"!
My vibration got better after lowering the car due to less DS angle - so there's that.
It is possible to have the angles reduced too much which WILL lead to potential u-joint damage as the joints need to rotate to keep the bearings properly lubricated - with no angle at either end of the driveshaft, u-joint damage is likely in short order.
I have a carbon fiber driveshaft since I couldn't stand the vibration any more and needed a strong driveshaft due to my heavy KB blown car and 4" longer driveshaft compared to a Fox 'Stang.
The dogbone is tuned to the resonant frequency of your system - mostly based on the length and other characteristics of the driveshaft. Since the driveshaft spins faster with gears, the tuning will still work, but it will be effective at different speeds.
wildstang90
87
Bristol, TN
Aug 29, 2008
  • Aug 29, 2008
I had a 93 LX with no dog bone and 3.55 gears never a vibration at all. I now have a 90 LX with 3.73s and its got a dog bone on it car has 180K miles on it and no vibrations on it. I have though about taking the bone off just to see what it does.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 29, 2008
#10
  • Aug 29, 2008
  • #10
Now that you mention it, yeah that is partially true, but there's a LOT that goes into it, like the height of your rear wheels and height of the tail shaft on the trany. I think the article i read was more along the lines of a custom hotrod type car where things were built more from scratch, making it much easier to throw off shaft angles...i just thought maybe the Mustang problems could be a spin off of this too.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,132
224
Massachusetts
Aug 29, 2008
#11
  • Aug 29, 2008
  • #11
He's talking about the pinion angle. Yes, it can play a roll in driveline harmonics. You want your pinion angle to be set at 2-3 degrees. Stiffer bushings require less angle. The reason for this is because under load, the front of the differential rises and the idea os to have the pinion and d/s now become straight. When you lower the car, you make them straight or reduce the angle to begin with. Now when you are under load, the pinion flange rises and now you have a slight offset and the potential for vibration. The larger diameter AL driveshaft just dampens it slightly due to less mass and most people think it's the cure when it's really a band-aid
Most guys lower their car without a second thought to suspension geometry anyway. Hell nobody ever worrys about their instant center when the lower their car...but they ruin it anyway. How many threads have you ever seen that say "I lowered my car..help me correct my pinion angle".
And with that said...i never adjusted my pinion angle or corrected for instant center when i lowered my 5.0
magnj
139
#12
  • Aug 29, 2008
  • #12
I had a thread a few weeks back about vibration. AFAIK my car is not lowered. Still on the fence about what to do with mine, the whole damn thing shakes. I'm going to be pulling a lot of it apart this winter I think.
R
Rick James
172
burlington new jersey
Aug 29, 2008
#13
  • Aug 29, 2008
  • #13
I just recently had a severe vibration issue starting at 4500rps and up no matter what,long story short i put in a aluminum driveshaft and bam,gone.Now on the flipside my brother in laws old notch had a almost identicle problem and we replaced the flywheel,put in a aluminum driveshaft ,harmonic balancer ,got rid of the solid motor mounts for brand new ones and it didnt fix it............he ended up selling the car.Checked everything and could not find it
just4bob50
504
Pa.
Aug 31, 2008
#14
  • Aug 31, 2008
  • #14
Not that I want to beat a dead horse hear, but I was under both my GT & LX and dont see anything that resembles a ( dogbone ) the GT I was the 2nd owner at 17000 miles 100% stock. The LX is all new from the DS forward. Could someone post a pic. It may help me track down a problem.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 31, 2008
#15
  • Aug 31, 2008
  • #15
It's literally bolted to the bottom of the pumpkin on the rear axle...you CAN'T miss it unless it's not there anymore.
magnj
139
#16
  • Sep 1, 2008
  • #16
Yea, you'll know it if you see it. Bolted to the bottom of the pumpkin with a bracket and 2 bolts, weighs ~8 .5 pounds.
331fastcoupe
9
#17
  • Sep 1, 2008
  • #17
Same boat can't get rid of mine etheir, and after bringing it to a mustang shop he told me it was fine after he adjusted the pinion angle and some other things tires rim's ect. Nope didn't change.
I changed the motor, trans, clutch, new rear gears,ballanced motor sfi matching balancer ,mounts ,k-member had a alum. drive shaft balanced,
nothing changes, it only does it under hard aceleration 3-4 gear right in the thick tourqe curve. It's so bad it feels like the cars drive trane will shatter in peices.
My only conclusion is a bent axle. What do you guys think ? I have 30 grand in this car and I am about to crush it.
magnj
139
#18
  • Sep 17, 2008
  • #18
could be an axle for sure, wondering the same thing myself about my issue, now I need to figure out how they hell I figure if it's straight or not?
NKau
1,346
Jefferson, WI
Sep 19, 2008
#19
  • Sep 19, 2008
  • #19
Same way you check a pushrod; roll it along a level surface (like a table) with the hub hanging off the end. You'll know if it's twisted/bent right away.
magnj
139
#20
  • Sep 20, 2008
  • #20
Probably should have done that first huh. Gonna check all the tires first, pull the driveshaft, etc...opening the rear housing was not fun for me.
1 of 2 Next Last
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
4K
Other Auto Tech Jun 13, 2026
427nostang
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
