New times For the 98 snake
tama
75
San Jose, CA
So I was out at Grudge night this past weekend to get new and better times in the cobra. This time I bought a set of Nitto 555R's 275x17 on my stock 17's.
My first run was my best run of the night. I did a brakestand in 1st gear to heat them up after backing in the waterbox and pulling forward. I launched the car at 2,000rpm with 28psi in the tires.
13.7@103mph with a 2.1 60ft.
A buddy droped my tires pressure down to 18psi on each side and another buddy ran my car the second time. He did a burn out in second and seemed to heat up the tire better and luanched the car at 3,000rpm.
13.3@104mph on a 1.9 60ft.
My second (3rd for the car) and final run was a better 60ft. but same mph and lower et. overall
13.8@103mph on a 2.0 60ft.
I was shifting at 7,000rpm and my buddy shifted at 6,500rpm.
He feels there is a drop in power above that rpm range.
Does this sound right? Did my car run average times for it's mods?
Anyway I plan on going out again and get more pratice and nail my launches better. I also plan on removing the IMRC's befor emy next trip and having the car re-tuned.
Any input or suggestions welcomed :nice:
It's all in the launch. That 13.3 is what the car should be running all day....
You do need a second gear burn out to really heat up those Nitto's to make them work. You should be able to get a 1.8 60ft out of them. I ran mine between 18-22 psi when I was closer to stock still. With a 3-3.5K RPM launch, feathering out the clutch, you should be able to ge a low 13 second slip.
It's been awhile, but I believe I was shifting around 6500-6700RPMS for the 1-2 shift, then 6800RPM's for the others. I make power all the way to 7000RPM's now so I shift at 7K on all shifts. Your power is probably peaking around 6300RPM now (if you have a dyno chart you will see the curve drop around there).
Good luck.
Good luck.
I was looking at the dyno ;ast night from 2 years ago and my friend who drove the car pointed it out that they graph starts to drop about 6,500 which he says why he was ablt to get a 1mph more then me :nice:
yes pratice is what I need..........thanks for the bit advice
that sucks. my car's only got 285-290 to the wheels you think then?? i was hoping for 13.2's at the track this time around with me and my friend driving. what's that like 350hp? waht you think my torque is at?
Have you dynoed your car yet? Have you put those gears in yet? hey a lot a views and 2 responses. What happened to all thos chatters out there? :(
i dunno but the gears will be in this week or next. deffff before i go to the track. thatd be a waste of time. wish i had dr's or slicks to borrow to see 12s. who knows. as long as i smoke imports on the street its ok. :D
I've got a '98 Cobra vert. Last May I ran it with Goodyear F-1 street tires on it, got a 1.8 60' and ran a 13.20 @ 105.8 mph. I had less done to my car than you, but i have more now. I will be running this weekend looking for 12's.
You should not bother taking your IMRC's out, you will only lose low-end power, quite significantly. Go get an Excal2, start playing with tunes, and work on your launch. Your car is not running bad at all!:nice:
By the way, when I ran it before, paying with shift points, my car went faster shifting at around 6300 RPMs, I have 4.10's.
True, you will loose low end grunt below 3,400rpm. the car will be launched about there-3,500rpm so low end is not what I need. this car is not a daily driver. The gears will make up for the extra kick I need to launch the car with. I was discussing with another cobra owner and he was telling me if my peak power is around 6,500 I should try shifting at 6,700rpm as so the rpms don't drop as low.:shrug:
98 Saleen Cobra said:
Hey tama... I noticed that you are located in SAn Jose C.A, just wonderin where cause i live in campbell...
heading up 280/680 merge on the way to fremont. Do you hang out/associate with any local car clubs out here in the bay area?
pm me your e-mail. I accociate with a few car clubs out here. Maybe you might be interested when car shows/meet and greets/BBQ's/special event happen around here. :nice:
