New to mustangs
nubie
9
Im looking at picking up a 94 or 95 GT because I want the 5.0L and i like the body style more than the fox body and I have a few questions.
First off one of my first mods will be 3.73 gears, headers and cat back with x pipe.
Now cams are where I'm needing opinions. My ideal cam would be something lopey and still make good power in the low and mid range. Also everything ive looked up for these cars keep giving me flat tappet cams but these are hydraulic roller motors correct? Im not looking to put down HUGE numbers with this yet just some simple power adding and the sound to boot.
Please dont flame me since I am new to these.
If you're planning on having a mild street car, try an E303 from Ford Racing or the Trick Flow stage one. I think the Trick Flow cam has a .499/.510 lift and the duration is 286/293. The E303 is a bit less, I believe .498/.498 and the duration is less.
Dustin makes some great points. Keep in mind the 94-95 OBD-II EEC extremely finicky vs the FOX A9L EEC platform. A cam swap on 94-95 is actually pretty limited. We know from experience that cam LSA over 112 is welcomed by the EEC and under 110 can wreak havoc with idle surging. You will see in a lot of 94-95 signatures things like custom cam, FTI cam, etc. Reason being split duration custom cams seem to be better than pulling a cam off the shelf. If you don't want to chase drivability issues look into a custom. If you go in the tech section sticky and read the information in there it could save you lots of time.
There's really no point in changing out the cam if you still have stock e7 heads. The stock cam is pretty good for mild setups(~270rwhp N/A), only problem is you don't get that nice lope at idle. Just my opinion, but I would go with at least a set of gt-40 heads and a cobra/gt-40/aftermarket intake before swapping the cam.
If you want sound over performance, then by all means swap out the cam. You'll gain some hp, but not as much as swapping heads/intake. Stock cam specs are .444/.444 lift w/1.6 rockers, 210/210 duration @ .050, 116 LSA. Something in the range of .500 lift, 220-230 duration and 114 LSA should sound nice and still run ok with the stock computer. Maybe a B303? YouTube - ‪1990 Ford Mustang LX 5.0 with b303 cam and flowmasters‬‏
Thanks guys youve been informative. The car im getting is a 94 gt. completely stock other than 3.73 ford racing gears. The seller is including a bunch of after market parts so I will get some info from you guys as soon as i get the car in my posession.
The 303 cam seems like a popular choice for a beginning cam. I plan on trying to do a head/cam swap on it in the time i own it but for now a little increase in power along with the sound and id be happy haha.
also when doing the cam what other parts do you suggest changing. I was thinking of going with full roller rockers but do the springs need changed as well? Also what about lifters? I may change those anyways for assurance.
I would suggest changing the pushrods and lifter as well. That's what we did. Check out our build thread. You will also need timing cover gasket set and might as well change your water pump while it's off. Don't expect huge gains from a cam swap. Look to change the intake and throttle body if funds allow. This will be a pretty nice pick up.
getting a trick flow intake and bbk 70mm throttle body with the car so that will be covered. Im not expecting a huge gain more like a smidge of a gain with the cam swap. I want the sound and a minute gain while i collect the parts for a complete top end swap (the wife wont let me do it all at once)
I've always thought 94-95 was like a family. We were a limited production run of 2 years, so we're kinda the bastard child of the Mustang world. At least with 96-98, they continued the 4.6 into the 99-04, so the support for them is generally the same. Newbie questions are always welcome here. We all have to start somewhere, right?
Ok, update...
I didnt get the 94 i was looking into. I am picking up a black 95 gt tomorrow morning that is completely stock and has never been modded.
I am definately going to change out the rear gears because whether it has the 3.08s or the 2 whatevers lol I wont be happy haha. Other than that headers, h or x pipe and exhaust will be a must.
