new to this genra of stangs 2000gt traction control
When it's on, it helps traction by detecting wheelspin. When a wheel starts spinning, it applies the brake to that wheel, cuts fuel supply, and retards the timing so as not to let it keep spinning. Great for in the rain/snow, but crappy for having fun. Just pull the fuse out if you don't want it and be done with it.
*shrug* my 2000gt has it. Its a button near the shifter area console kinda below cd player junk. And Black button when ya press it, it says Off underneath it. And it turns itself back on every time i shut it off and turn it on. Yeah traction control sounds lame! lol
If its that easy do it!
If its as easy as CManT says, just pulling a fuse to kill it, DO IT! There's nothing more embarassing than dumping the clutch expecting a spectacular smokey and the engine falls on its face. :nonono:
TCS = worthless
i wonder why some 2000 GT's have it and some dont??? :scratch: :shrug:
Anyone who says that traction control suxx and is for loosers etc does not know & understand the function of it.
I agree that it would suck if you couldn't turn it off, but that is not the case. I would never allow my wife to drive my stang if I didn't have the traction control. It has saved my ass several times when driving carelessly on dirt roads or when the 1st snow in the winter falls.
The KB is going in on friday and I guess I have to pull the fuse and tell the wife that she can't drive the convertible anymore :D
TCS still "sux."
Traction control is part of a series of three braking technology developments that began appearing in vehicles in the mid-eighties. (Note: Many German vehicle manufacturers call traction control by its original German name: ASR traction control. ASR stands for "Acceleration Slip Regulation." In chronological order, these developments are: anti-lock brakes, aka ABS (1978), traction control (1985), and stability control (1995). All three technologies come from the laboratories of Robert Bosch Company in Germany, and all address the issue of improving contact (traction) between your car's tires and the road.
Traction control works at the opposite end of the scale from ABS -- dealing with acceleration rather than deceleration. Still, since many of the same principles apply to both systems, it might be best to visualize it as sort of ABS in reverse. ABS works by sensing slippage at the wheels during braking, and continually adjusting braking pressure to ensure maximum contact between the tires and the road. You can actually hear the system working (a grinding sound) and feel it (the pedal pulsing).
:D Is there a smiley for :smartass:??
I just have less faith in a machine to operate itself in wet conditions than I have in my own abilities when I am behind the wheel.
Mossberg said:
***IF YOU PULL THE TRACTION CONTROL FUSE, YOU ALSO LOSE ABS!***
I've had my '01 for almost three years now, and
just recently discovered that you can turn the
ABS on/off thru the radio. But for the life of me,
I can't figure out why anyone would disable the
ABS system.
