NEW WITH ???'s
jo-shmo
12
First I'll introduce myself, my name is Josh, I just turned 26 and this is my second stang. My first was an 83 with t-tops, dark blue with black, and 85k mi. that had been garaged its whole life. I bought it from the original owner who had dropped in a 5 spd and full Boston pro-series sound system. But being 17 at the time and apparently also retarded I sold it for $2500. I think I should add though that I sold an 87 Fiero GT to buy it.... that should count for something.
Now almost 10 years, and many many many hours of time spent in a scraper driving around a coal mine later, I've got another.
So far it has new paint, interior, 5 lug conversion with 18x9 Enkei Zues wheels, rebuilt tranny w/shift kit, rebuilt posi rear with 4:10's, long tube headers with x-pipe and flowmasters, and just before I purchased it a stock longblock was dropped in.
My problem is that it think the shift kit and low gears are working against the stock cam. It pulls hard to about 4200 rpm but then falls flat on its face. Well, not exactley flat, the rpm's continue to climb but the loss of power is alarming. I've thought of a hundred different ways to improve it but from my limited experience it would basically be experimental.... what do you guys think?? Keep in mind that I'm married ( so I obviously have a tight budget ) and its parked for the winter so downtime isn't a problem.... although knowhow might be.
oops
Low RPM capability is more a result of the stock heads than it is the stock cam. The stock cam has been retained in some very, very fast cars. It is not a half bad grind for performance, considering it's the stock cam.
So what your saying is that when I mash to go pedal the first thing to quit producing would be the heads. So if I could swap the cam or the heads, I should go with heads first?
That sounds about right for a stockish 5.0. The 4.10 is just getting you there quicker. lol
It's all a matter of what your overall goals and budget are. A quick way to open it up on top: bigger maf, tbody, and a nice set of heads. To most of us that's not exactly cheap, again, depending on your situation.
Very nice GT btw! Welcome aboard.
Is that an aftermarket shifter or a trimmed stocker?
Exactley. You go fast for a VERY short time.
This is gonna sound like crazy talk but.... I want the most power for the least amount of money possible.
Thanks. And its a trimmed stocker.
I saw a Typhoon intake in the paper the other day for cheap, but usually try not to use a knock off part.... but if anyone has good things to say about them I'd make an exception.
If you want a thread moved ask me or one of the other Mods. That's why I merged your other threads.
Thanks
I did ask. You put the kabosh on this one lightning fast so I went back to 5.0 talk and asked for that thread to be moved. Waited 15 minutes with no change so I tried doing it myself.
I'm not trying to step out of line, I just want to get my questions answered.
:flag:
:flag:
It's all good man. Next time send me a pm.
Oh and I'm with them on the heads. The stock cam ain't that bad, but the heads (untouched) not as good.
So on a stock set of heads how much improvement would roller rockers be? I'm guessing not much. Also, from experience, whats the best bang for the buck heads on the market. Not the ones that if I spend an extra $800 bucks I can squeek out an extra 7hp, but the everyday, not the best but way better than stock and well worth the $$ type head.
That's not such an easy one to answer. Everyone has something different to say about that. You could see how much it would cost to get your stock heads ported. That may be cheaper than a set of new heads.
Edit: I fixed the title.
I agree with 85ragtop. I actually don't like getting into recommending certain types or brands because there are so many factors. Some might say heads, another might say nitrous. Some might say ported stock heads, junkyard Explorer heads, or entry level aluminum heads. Just start researching what's out there and decide which way you want to go. If there's one thing you have with a 5.0: it's options! lol
With a stock motor you have a lot of options. Stock heads are holding you back but not as much as the stock intake. If you want to take baby steps and upgrade as needed I would start there... especially if you are on a budget. For a good street build I suggest a cobra/gt-40/explorer or an Edelbrock. This will maintain your bottom end torque and give you more power throughout the bottom end. Others like the TFS and Holley will give you great top end but won't really come in till 3k rpm. Another option is to get your lower ported by TMOSS @ www.tmossporting.com . Seeing that you have 410s... you will likely run out of higher rpm pretty quick. For heads, Bang for the buck TFS is hard to beat. Edelbrock is another great option. AFR makes a really good head but you pay for it and for the price you can probably had some TFS heads ported for close to the same price.
Kevin
Roller rockers are a minimal improvement. They don't really shine till you have really high lift cams that really wind out on the RPMs. For a street motor, unless you are going to get some aluminium heads and have to change anyways, it isn't worth it... IMO.
Kevin
I suggest a cobra/gt-40/explorer or an Edelbrock. This will maintain your bottom end torque and give you more power throughout the bottom end. Others like the TFS and Holley will give you great top end but won't really come in till 3k rpm. Another option is to get your lower ported by TMOSS @ www.tmossporting.com . Seeing that you have 410s... you will likely run out of higher rpm pretty quick. Kevin
I checked out the porting website... $120 to port the lower ain't bad at all. I'm curious though how that compares to the gt-40? From the few places I checked it looks like I could pick up an Explorer intake for about that. Also, it looks like a set of gt-40 p heads are cheap.... so either this stuffs cheaper than I expected, or I'm looking at junk.
I could probably drop $500 without the wife getting too upset.... I had to allow a grace period there after shelling out for the new interior, that hurt...
but from what I gather I wouldn't need more than a ported stock lower intake with a decent set of heads but whats the difference? Gt-40 = alluminum gt-40 p = cast?
The Ps could be found on factory explorers but I can't remember which years. They are cast but if I remember correctly your exhaust manifolds might not mate up to them correctly... special headers are required. If you do switch to aluminium, you will free up almost 50 lbs off the front end of the car which is a good thing for these foxes...
Kevin
Honestly, with $500 thats not going to do much unless you can get smoking deals. If you can save up $1000 then your deff in good shape. Some used iron gt40's, cobra performer gt40 something like that intake, E303 cam or equal, 65mm TB and egr spacer. That would be around $1000 or so. But if you've only got $500...spray never hurt anyone.
I never said I couldn't spend a $1000, I just said that the wife would be less angry if I didn't.
Its not the $$ so much as what to go with. I'm not concerned with trimming weight etc, and I'm waaaaaaay not even considering nos. I'm not looking to build something to take to the track, I just want more power.
At this point I've ruled out most aftermarket companies for heads and intake. Seems like the bang for the buck really declines once you step up to edelbrock etc. Now I'm just trying to figure out if the explorer heads/intake are the same as gt40/cobra and if not which would be better. And also how far I can go before I need a custom tune?
