newbie engine question
  • Thread starter Thread starter cjjacquez
  • Start date Start date May 6, 2006
C
cjjacquez
  • May 6, 2006
Hello guys!
I have a 1973 Mustang Mach 1 with 4 speed manual tranny and electric windows. The car does not have the VIN and I dont knok what engine has on it.
IF 351C or W or 302 I have not Idea, I have digital pictures and I would like to know if somebody from here can send me an e-mail so I can reply back with digital pictures to help me identify my engine
my email is
josue.jacquez@honeywell.com
Thanks for your help
66HertzClone
428
Central New Jersey
May 6, 2006
  • May 6, 2006
Go here, http://www.cardomain.com/register Free web hostoing of your photos, you can create a link here to go dirctly to your photos or attach them to your post.
A 302 and 351W will have the thermostat mounted vertically, 6 valve cover bolts (each cover), and fuel pump mounting bolts in a horizontal plane. A 351C will have a thermostat mounted in a horizontal plane, 8 valve cover bolts (each cover), and a fuel pump with the mounting bolts in a vertical orientation.
Without any other ID, the only way I know of to tell the difference between the 302 and the 351W is the height of the deck. You could measure from the oil pan mounting surface the the head gasket. Hard to measure, but my 302 block is close to 5". Hope this helps.
BornInAFord
199
Bend, OR 97701
May 6, 2006
  • May 6, 2006
So there's no VIN on a little metal plate on the dash at the base of the windshield? The middle letter there should tell you what engine your car came with (i.e. H, F, M, etc).
A quick visual identification of a 302 vs 351W vs 351C will be valve covers (you can set a ball on the 351C valve cover and it won't roll off, plus it has 8 bolts, not the 6 like the 302 and 351W) and the thermostat in the 351C will be on the timing chain cover. This is in addition to the info listed above by 66HertzClone. The 351W will have ribs coming from the distributor area toward the timing chain cover, but the 302 will not.
Daniel
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
R
New Member, needs help with built '04 engine
  • rollo19
  • Aug 6, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 6, 2025
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
