Greetings,
I finally fired up the '69's 302 today for the first time after the rebuild. Everything went as expected except for one thing - after 15 minutes of cam break in, there was still smoke coming out of the left side exhaust pipe... a lot of it.
The right side exhaust was clean.
The smoke was whitish gray and hung heavy in the air. It did not seem to disipate like water vapor would. It did not really smell like oil either.
What could this be?
Here's what I did to the engine:
'69 302 bored +.030, speed pro pistons, moly rings, edelbrock 7122 cam, performer RPM intake, 600 cfm carb, hand ported stock 302 heads, new valve guides, hardened seats, screw in studs, full roller rockers, etc.
I bought used long tube headers from a friend, sand blasted them and coated them with Eastwood header coating. When I started the engine the headers gave off an ungodly amount of smoke for about 5 minutes.... It eventually stopped but the smoke out of the left pipe continued. I doubt if there is any connection here....
I am running a PCV out of both valve covers during break in (as recommended by a friend) - one to the carb base and one to the intake just below the carb. Could this have something to do with it? Yea, grasping at straws - don't want to tear this thing apart again....
I assume i either have a water passage leak, a blown head gasket (there were several backfires trying to start it initially), a piston ring problem, etc....
Any suggestions would be appreciated.
THANKS!!!!!!!!!!!!!!!!!!!!!!
What could this be?
