  • SN95 4.6L Mustang Tech
next mod?????
  • Thread starter Thread starter supastang03
  • Start date Start date Jun 25, 2005
supastang03
214
Miami/Gainesville UF
Jun 25, 2005
  • Jun 25, 2005
ok guys...u all know best, so i was wondering what u all think i should get as my next mod. Im thinking steeda underdrive pulleys, but maybe theres something better i havent thought of yet. ill spend up to 350, and im prob not going to get gears because i drive my car from miami to gainesville often. please help me out!
'03GTinFLA
486
St. Petersburg, FL
Jun 25, 2005
  • Jun 25, 2005
I'd say gears.
Ha ha. I got to say it first.
Trust me and there will be others that will agree with me. I drive an hour each way to work, cruising 80-90. I have 3.73's and no issues. I think 90 mph is around 27-28 in the RPM's. There are calculators if you want to be exact, but no gas mileage problems or anything. It's all good when it comes to gears. People will probably tell you to go 4.10's. I have 3.73's so I can't speak for the higher gears. The only problem is, with install it's gonna be more than $350, but it's worth every penny.
Other than that, I would say Steeda pullies, a timing adjuster, mayber Accufab TB/Plenum. I have a Predator and I liked that, as a mod and on the SOTP meter.
Alot depends on your long term plans. ALso is it an auto or manual, do you visit the strip?
Just my .02
supastang03
214
Jun 25, 2005
  • Jun 25, 2005
i knew that was coming...
well about the gears, what will it actually do for me? i know basically the gears are shorter resulting in more time spent in the maximum HP range, but will i notice a difference in acceleration? i want something that will give me a good increase in acc., and ive heard underdrive gears are especially good for low end torque. also, what exactly does the timing adjuster do, and what benifits will i see from it. basically if i get gears, thats all i will be able to buy for a while, so i was thinking of maybe getting some pulleys and something else. thanks alot, as u can see im still pretty new to all this. oh and btw its manual.
BuffaloZone
411
  • Jun 25, 2005
In that case...
gears
Best mod I've done so far. Can't wait until I get my KB!!!
9646gt
595
Holloman AFB,NM
Jun 25, 2005
  • Jun 25, 2005
gears will greatly help with accel... As far as pullies go..if you plan to go blown you may be wasting your money as from what I hear you cant run the pullies with a SC..someone care to correct me? but if you want to stay NA then I say go gears and THEN pullies!
'03GTinFLA
486
St. Petersburg, FL
Jun 25, 2005
  • Jun 25, 2005
Yeah i think the UDP's are a good choice. I'm not going that route b/c of the KB in my future. I go by the SOTP meter, cause I don't get to the track much. I've heard some people can feel the UDP's. The timing adjuster advances your timing for some extra HP, but then you have to run higher octance gas to avoid detonation, sounds like someone shaking a tin can with rocks in it and this is not good for your engine. So if you don't want to run more expensive gas, forget that one. The handheld tuners are in your $350 range. I'm not going to say which one to get, just search for SCT or Predator and you'll have plenty of debates to read. My predator was used to adjust the speedo for my gears, turn off the light due to offroad prochamber, advance the timing (running higher octane gas now) or retard the timing when the blower comes in, and it gave me a bit more torque and better throttle response. There are lots of other things you can use the tuner for, but I'm still playing with it and learning. If you can save up maybe go with long tubes or VT cams. Here in florida we are blessed with no emmissons testing. But brands of LT's are another debate you might want to do a search about. And if you can do the install yourself you'll save lots of money. VT stage I is about 22 hp and Stage II's around 33 hp. Stage I no need to change springs, stage II require spring change = more money and II's benfit from a dyno tune. More info than you want but I'm bored as hell.
supastang03
214
Jun 26, 2005
  • Jun 26, 2005
thanks for all the insights guys...i guess im kinda leaning toward gears now...i know of a place for 399...installed. best ive heard. but now comes the huge neverending debate on 373s or 410s...what do u guys suggest?
9646gt
595
Holloman AFB,NM
Jun 26, 2005
  • Jun 26, 2005
if you dont plan on running 90 down the interstate every single day then go 4.10's there is nothing like it! Well..unless oyu went 4.30 or something crazy but then you better stick to the city streets..4.10's will for sure put you in the seat very well
C
Fuel 01 mustang coup 3.8 looking for help with finding a schematic , fuel level sensor
  • Chipstack8
  • Sep 7, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 8, 2025
Chipstack8
C
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
