next on the list...
  • Thread starter Thread starter 351ford
  • Start date Start date Oct 20, 2005
351ford
Fountain HIlls AZ
Oct 20, 2005
  • Oct 20, 2005
ok, im up to ignition and a carb. an engine builder here in phoenix told me at least a 950cfm carb for a 408 that will be limited driving on the street and to be sure to go with holley, i guess edelbrock sucks with nitrous (i dont think they have a carb that big anyhow). any other suggestions would be great! as for the distributer im not sure at all. I imagine that msd is the best but it seems like all their distributers require a box (acording to their product description) this is my first stang and engine build so any and all help is great!!
thanks
G
gzminiz
200
Phoenix, AZ
Oct 20, 2005
  • Oct 20, 2005
Grab a Mighty Demon. I am building a 408 stroker and plan on the mighty demon. Heard nothing but good things about their carbs.
Have you been using local shops for parts and service? I am local to you and just starting my restomod project could use pointer on local shops (sorry off topic)
351ford
Fountain HIlls AZ
Oct 20, 2005
  • Oct 20, 2005
i had my block rebuilt by a guy in phoenix that has a shop set up in his home i can give you his number if you like, he does really good work and is very reasonable. other than that iv been doing it all my self so far and ordering most of my parts from summit or going to lopers. i bought my stroker kit from chp along with a main girdle.
by the way does 950cfm sound about right to you?
G
gzminiz
200
Phoenix, AZ
Oct 20, 2005
  • Oct 20, 2005
I was planning on running an 850 but i also wasn't planning on running nitrous. You should be good with a 950.
302 coupe
1,952
Macon, Ga.
Oct 20, 2005
  • Oct 20, 2005
what heads, cam, rpm range for the 408? 950 seems a bit big (and I like big carbs) unless you're really gonna be turning it high.
G
gzminiz
200
Phoenix, AZ
Oct 20, 2005
  • Oct 20, 2005
even with nitrous? Nitrous loves fuel, his tag shows specs ( '70 sportsroof 408(351w) Probe engine kit, girdle, vic jr heads, .600int .597exh, vic jr intake)
302 coupe
1,952
Macon, Ga.
Oct 20, 2005
  • Oct 20, 2005
the fuel for the nitrous doesn't go thru the carb.
With the vic jr heads and .600 cam, I still think 850 would be plenty. Without the n2o, I'd expect 450-475 hp with good compression maybe, 850 cfm will be plenty.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Oct 20, 2005
  • Oct 20, 2005
Honestly I think you better switch engine builders.
950cfm is good for approx 600+hp (before nitrous) and I really doubt your 408 is putting out that kind of HP without a power adder.
Carb's arn't used for nitrous..you do NOT need a larger carb when running N2O. Nitrous should have no effect on the carb. The carb does not supply the extra fuel, and actually breaths LESS air while the N2O is in use.
Seriously... this engine builder really doesn't sound like he knows what he's talking about. I think you should find a new builder.
G
gzminiz
200
Phoenix, AZ
Oct 20, 2005
  • Oct 20, 2005
please note I am not the engine builder, I merely gave my thoughts on the subject. The nitrous stuff was my (aparently horribly wrong enough to be ostracized) assumptions based on my knowledge of nitrous. Thank you for correcting my perception of how the extra fuel is delivered with nitrous.
F
ForceFed70
4,818
BC Canada
Oct 20, 2005
#10
  • Oct 20, 2005
  • #10
hehe.. sorry dude. It's perfectly OK for you or I to make a mistake like that...I can see why you might think that way. Big difference is that we're not engine builders.
351ford
Fountain HIlls AZ
Oct 20, 2005
#11
  • Oct 20, 2005
  • #11
actually the guy that built my engine and the guy that told me at least 950cfm are 2 different people, my fault i was unclear, but anyway im glad i asked about that so i didnt make a very expensive mistake. and about the distributer, whats my best bet???? msd with box???
bnickel
5,640
lubbock, texas
Oct 21, 2005
#12
  • Oct 21, 2005
  • #12
with the specs you have listed for your engine i wouldn't even consider NOT running a good distributor and a CD (capacitive discharge) ignition box of some sort. MSD is probably the best bet and they have a lot of options. i would call their tech line and get them to recommend a good complete system for your engine. i'm talking distriutor, coil, wires ignition box and anything else you might need
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Oct 21, 2005
#13
  • Oct 21, 2005
  • #13
One advantage you can get with a MSD box is the ability to retard timing when the nitrous kicks in.
302 coupe
1,952
Macon, Ga.
Oct 21, 2005
#14
  • Oct 21, 2005
  • #14
The Digital 6 box has such a feature built in, amongst other nice features.
F
ForceFed70
4,818
BC Canada
Oct 21, 2005
#15
  • Oct 21, 2005
  • #15
Can't go wrong with MSD
fvike
335
Mosjøen, Norway
Oct 22, 2005
#16
  • Oct 22, 2005
  • #16
The Crane distributor doesn't use a box, if you want to avoid that.
http://store.summitracing.com/defau...-1601&N=400078+4294925143&Nao=20&autoview=sku
They're also delivered with a small cap, to avoid air cleaner drop bases.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • dan50
  • Jul 18, 2026
dan50
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
