cant decide which to do next. My mods are in my signature. what would i benefit most from here? Ford Racing Unequals or a 75mm pro m mass air meter?
notchback said:stock maf , intake and tb is good for lows 12's....will support 300 hp
if you use your nitrous a lot you will definitely benefit from headers...go 1 5/8" long tube
if you don't use a lot of nitrous .... save your money for now , for heads
don't do an intake til you get heads, that is THE biggest waste of time and money known to a 5.0....even though 100 people will tell you do so.
it isn't worth 7 hp on a stock headed car.
i know this from experience, i did a gt-40 w/ ported lower and the car ran the same as b4.
i only put it on cuz i had it (and gt-40's look awesome) but doesn't do squat.
N8Miller said:OT: baxter, did you get your kit? i lost your AOL IM name.
5spd GT said:A ported lower sounds like a good idea.
Your not going to gain an "easy 3-4mph" with just an intake swap. That simply isn't going to happen.
tmoss said:I'll let an email from a ported lower stock intake say it.........4 tenths is doable if you have the rest of the combo right..........
Subject:Re: ported lower
Date:Fri, 29 Oct 2004 20:51:08 -0500
Hi Tom.
I got some new times for you. Run the car yesterday. I run new best.
[email protected], [email protected], [email protected],[email protected], [email protected]
- I improved .46 tenths & gained 4 mph. But I know there's more in it. Do you have any idea what can help me. The only other mod i added with your ported stock lower was a 65Tb. The car really lights them up on the street. Also I had a cooling problem it kept running hot I give it a good cooldown but the water wasn't running right so I think I will get you new times next week (added above later). My radiator busted and ended my night early fan clutch give out and the blades broke thru.
Thanks bud
Frank
NKau said:Figured I'd post that just in case you missed it Dave![]()
5spd GT said:I didn't miss it
Was the variables the same? I gained 3mph from one track trip to another with no changes whatsoever. Just drove it different.So think an intake change would give me 7mph
5spd GT said:3-4mph is the equivalent of a broad "torque curve" of 30-40hp roughly. So I ask you, from an intake?![]()
NKau said:I'm talking about a car running consitent 96 mph traps running consitent 99 mph traps after an intake swap.
A better intake gives you 15+ hp with stock heads (I think we can agree there). I picked up 3 mph with nothing but a performer intake with what are to the best of my knowledge stock heads. Trapped consistent 96.x's with the stocker, and consistent 99.x's with the performer. The numbers may not make sense, but they are what they are. My sig should be updated, but I'm waiting until the heads go on.
